More Buffeting Questions
Old Aug 8, 2010 | 07:36 PM
Danthern's Avatar
Danthern
Default More Buffeting Questions
I know it's been done to death but I'm hoping for some fresh thought. I just put a HD Super Sport Windshield on my 2010 FXDC. While the improvement is very signifigant as far as the wind in the chest goes, there is some buffeting. Not as bad as some I've seen described, but enough to be annoying. Starts around 55-60 mph. I've adjusted the shield height up and down the forks and I have a fork bag that I've had since I bought the bike. Used 3/4 and full face helmets. I seem to get less disturbance with the shield all the way at the top of the forks which means I look through instead of over for the most part (a whole different issue, right?) although if I straighten up and raise my chin a bit I can see over. By feeling wind flow with my hand at 70 mph the shield seems to be doing its job deflecting air over and around my head. The air is coming from the bottom up the sides of the tank. Helps somewhat when I hug the tank with my knees. When I extend my legs parallel with the tank the buffeting is 97% gone. The arm across the chest test doesnt do much in the way of improvement so I'm doubtful the vest is a cure. I've read much on the subject of lowers, deflectors, whatever you want to call them. Even if I wanted to use them I can't see where they are made for Dynas. I wonder if a tank bag would make a difference...? I'll pop the shield off in town but I'm planning an excursion of the Blue Ridge Parkway and I'll need the shield (approx 1000 mil round trip with interstate on the way up). Any thoughts or advice? Sorry for the lengthy post. Thanks in advance for any tips, advice and/or opinions.
Old Aug 8, 2010 | 07:49 PM
Chicagosong's Avatar
Chicagosong
I'd be curious what has helped as well. I've got 57338-08 on my FXDF and while I do look through the windshield to some degree (considering cutting it down a bit) I too get the buffetting and wondering if cutting down or using a laminar lip or what would be the best suggestion. I'm 5'9 and as is true with most mods I'd prefer to not drop money on trial and error. Thanks.
Old Aug 8, 2010 | 08:41 PM
terrible1one3's Avatar
terrible1one3
I have a 2007 FXD with the Harley Quick Detach windshield, full size.
I was getting a lot of buffeting and the top of the shield was right in my line of sight. Doing the measure test I needed to take 3 inches off. I cut 2 inches off and could see plenty but now the buffeting was horrible.
I thought it might be from lowers but no test really changed/reduced the buffeting except when I put my hand in front of my forehead and up like halfway through a salute. Then the buffeting goes away, aka the shield is dumping the air right on the helmet.
I contacted Cee Baileys asking if I should go get a taller screen and they said the only way to get proper protection on a Dyna is a taller shield where you are looking through it. You sit too far away from the shield to go with a properly sized one. I am going to order the +4 inch and report back on if it has cured my buffeting issue.
I don't mind looking through the shield. I look through a windshield in my car every day and rain beading technologies are awesome these days. I hope it cures the buffeting!
VAnightster
Jun 20, 2019 07:48 AM
kmoberlypilot
Jun 16, 2014 06:49 AM
MiniWolf
Oct 10, 2012 09:52 AM
2004Sierra
Jun 21, 2011 09:47 PM
doc_cj
Apr 19, 2010 10:31 AM
