cableless throttle
Old Aug 10, 2010 | 10:20 AM
Grendel4's Avatar
Grendel4
Originally Posted by rdondes
Changing to fly-by-wire sounds expensive - as in the $1,500 range. Nice if you have lots of discretionary income.
I bet you could get a whole system from Toyota on the cheap.
Old Aug 10, 2010 | 10:55 AM
jinx44's Avatar
jinx44
LOL. Just make sure your brakes are good!
Old Aug 10, 2010 | 03:06 PM
Coxbow's Avatar
Coxbow
1500$ that's indeed a lot just to get rid of a couple of cables !
Old Aug 10, 2010 | 07:27 PM
HDTech74's Avatar
HDTech74
I'd say upwards of $2000. the intake alone retails for about $1000.
I wouldn't even bother.
I have seen those FAIL lately with staggeringly alarming regularity.
try 5 systems in a month. All brands new bikes.
The lag in the system sucks.
Also on a touring bike the whole wiring harness lays in a plastic trough under the tank and not through the frame like on a dyna.
save your money and build a big motor.
Old Aug 10, 2010 | 07:45 PM
Yasky1997's Avatar
Yasky1997
Custom Cycle Controls make some nice internally wired and cabled bars. They look great but not cheap
Old Aug 10, 2010 | 08:22 PM
parts eeter's Avatar
parts eeter
I have heard of few guys that had internal throttle cable setups as well as clutch setups and they said they were sticky and didnt like them.
Old Aug 10, 2010 | 08:27 PM
HDTech74's Avatar
HDTech74
it sounds cool in theory but I don't like internally running things.
if something breaks or a wire shorts you're pretty screwed.
how would it work if you had z bars? how would you get a throttle cable around those corners?
I could have internally wired my fxd but chose not to.
Old Aug 10, 2010 | 10:00 PM
Yasky1997's Avatar
Yasky1997
When I ran my wires internally I used the black mesh expandable tubing so there would not be any issues with wires shorting out. At least not because of chaffing on the steel bars.
Old Aug 11, 2010 | 06:04 AM
Coxbow's Avatar
Coxbow
It looks indeed a bit complicated, so I’ll maybe go with a 1 cable throttle, my idea was to go with a fly-by-wire throttle and a internal “throttle like” clutch (yes it exists)
dc3plt
Apr 11, 2015 06:44 PM
anicely
Sep 4, 2013 10:04 PM
Po2387
Mar 26, 2011 11:49 PM
Coxbow
Nov 29, 2010 06:28 AM
xtremechopper
May 1, 2009 07:15 AM
