Switch Housing Kit
Old Sep 3, 2006 | 07:08 PM
CHEESE's Avatar
CHEESE
Default Switch Housing Kit
I'm replacing my switch housings and just picked up the chrome kit. I was suprised to see that the instructions say you need to pull the turn signal wires and release the wires from the connectors in wide glide and street bob models, but it doesn't have this step for any other dyna. I thought they all had the signals up on the bars in 06, wouldn't they all be the same?
I have to admit, I'm a little frustrated because i didn't envision this project to be such a PITA!
Old Sep 3, 2006 | 07:22 PM
jackyl's Avatar
jackyl
Default RE: Switch Housing Kit
believe it or not .its not that bad of a job to do.the only thing that is a pain is the little clips to your throttle cable.like to fall off.keep a good eye on them,and u will be all right.about 1/2-1hr job.just enough time for a couple beers in the garage
Old Sep 3, 2006 | 07:59 PM
CHEESE's Avatar
CHEESE
Alright, I'll take your word for it. I've fought with the throttle and idle cables before, so if the wiring is easier than that I'm not so worried. Thanks.
Old Sep 3, 2006 | 08:05 PM
jackyl's Avatar
jackyl
ya the only thing you do is unbolt the housings.and thier is a small tourqe bolt in thier,holding your buttons in place.take that bolt out and pull your buttons out.know just bolt the buttons back on the new housings and put back together.make sure you dont pinch the wires when you put the housing back on your handlebars.after you install them,make sure all your buttons work properly.and thats about it.
Old Sep 3, 2006 | 08:07 PM
jackyl's Avatar
jackyl
and you dont have to remove the wires from the connectors either.i have a bob too,and didnt have to
Old Sep 3, 2006 | 08:22 PM
CHEESE's Avatar
CHEESE
So there was enough room to pull the wires through without taking them out of the connectors? Sorry, I'm just dreading this job.
Old Sep 3, 2006 | 09:42 PM
CHEESE's Avatar
CHEESE
I just looked briefly at the new housings and I can't see any way that I would get the turn signal wires through without taking them out of the connectors. Can you give me a little more detail on how yours went?
Old Sep 3, 2006 | 10:29 PM
clayman's Avatar
clayman
Hey dennis it looks to me as jackyl has relocated his turn signals.
Old Sep 3, 2006 | 10:46 PM
CHEESE's Avatar
CHEESE
Ah yes, it does. That doesn't help me then...
Old Sep 8, 2006 | 12:12 AM
CHEESE's Avatar
CHEESE
Alright, I'm counting on someone to argue my logic, as it's often flawed.
Rather than get into the wiring in the frame, disconnect it, pull the wires from the connector, etc., couldn't I just cut the turn signal wire where it enters the switch housing and solder it when I put it all back together? I'm better with a soldering iron than with wiring connectors...
Someone please tell me why this is wrong, or I'm doing it tomorrow.
