Internal wires, HELP
Old Aug 22, 2010 | 03:01 PM
greenyetti's Avatar
greenyetti
Default Internal wires, HELP
Any tips on getting harness pushed back into frame PLEASE.
ran internal wires through my bars on my 2003 Superglide, havin a hell of a time cramming the harness back into the frame back bone. ( guess I should've just spliced the wires but figured I'd do it right and access the connectors)
now I'm about ready to shorten the whole harness just to get it back in.
Old Aug 22, 2010 | 03:36 PM
spaceblue's Avatar
spaceblue
Try tugging from the back under the seat. Thats what I did.
Old Aug 22, 2010 | 04:03 PM
8541hog's Avatar
8541hog
+1
That is where the slack is stored, if you just pulled on the wires from the front to get them out, I would take the seat off and inspect the wires under there to make sure you did not damage them.
Down under everything else you will find a large bundle of wires that lead up into the frame, that is the wires you are talking about.
It is a very easy push-pull deal to get them in and out to work on the connectors up front.
Old Aug 22, 2010 | 06:07 PM
greenyetti's Avatar
greenyetti
whew! got er done and all buttoned back up. All tested and working. Thanks for the input. Wedged my hand between rear fender and tire, inches at a time pull in back, push from front until all done, then pulled excess up into area under seat.
Definately recommend second set of hands for this job.
Thanks again
burgerusmc
Dec 10, 2013 07:33 PM
stl jeanes
May 26, 2013 02:56 PM
big kal
Jan 12, 2013 04:03 PM
JoeGrapes
Jul 4, 2009 12:38 AM
synisterglide
Jan 1, 2008 09:55 PM
