98 Wide Glide Dyno Graph
-Mackie Performance Package (DM 580 cam, pistons, springs and head work)
-Mikuni 42 carb and Mikuni Air Cleaner
-Rinehart Exhaust
-HI 4 single fire ignition
The Dyno chart attached shows a maximum of 84 hp/83 tq at 5600/4900 rpms respectively. Seems good to me considering that the motor is still 80 cubic inches and that equates to a little over 1 hp and 1 ft-lbs per cubic inch. The only thing that looks odd to me is the dip in torque, 62 ft-lbs at 3100 rpm. The bike pulls hard and the dynometer in my *** says that it has plenty of power.
I plan on taking it to my local shop for another dyno run sometime in the near future but I wanted to see what you guys thought about the graph and numbers. I've been reading and hearing a lot about the newer motors and the numbers they are getting but I will stick with my little 80 inch. This setup should be relatively reliable too, which is very important to me. Feel free to bash, compliment, offer observations or state your results with similar setups.
