Footpeg spring washers
Old Aug 30, 2010 | 09:54 AM
rh8234's Avatar
rh8234
File would be easier than tin snips, unless you got some really tough tin snips.
Old Aug 30, 2010 | 12:43 PM
bbqbrisket's Avatar
bbqbrisket
if snips are too hard, maybe I should use a bench grinder
Old Aug 30, 2010 | 02:12 PM
parts eeter's Avatar
parts eeter
I will be checking out the Home Depot as I need to install new hardware front and back for the footpegs and dont wanna use the crappy stock washers. Stainless for me and snip em.
Old Aug 30, 2010 | 02:58 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Why not just try bending them first as SCLonghair suggested. Would appear to be the easiest thing to do first; then onto cutting if that did not work.
Old Sep 1, 2010 | 01:32 AM
HemiOrange's Avatar
HemiOrange
I was at Ranch and Home (local owned) today, who happens to carry the exact same bins of fasteners as Ace Hardware. I was in the stainless steel section and saw the wave or spring washers that you mentioned. Lowe's might also carry the same selection, but I'm not sure.
bcane98
May 17, 2012 12:47 PM
Shizims
May 18, 2011 12:10 PM
Boxer 6
Dec 1, 2009 08:31 PM
bladesmith
Jan 31, 2008 11:09 PM
BigGeorge
Apr 27, 2007 11:18 AM
