Harley tradition
Old Sep 5, 2010 | 04:45 PM
CKS's Avatar
CKS
Default Harley tradition
Question, I was running down the road at about 60 this afternoon & had a loud pop & loud whining sound, The sprocket appears loose now, Tranny seems to be shifting gears but no drive to the wheel. primary chain & clutch look OK, What do you think happend? Stripped sprocket or tranny trouble? Oh yes its a 1994 FXDWG.
Old Sep 5, 2010 | 05:08 PM
rocket23's Avatar
rocket23
Time too start tearing it down till you find the problem. Hard to speculate til you actually see what's blown. At least thats how it seems. One thing is sure, your tranny is f*&ked.
Old Sep 5, 2010 | 06:16 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
See if your rear sprocket bolts (to rear hub) didn't shear.
Old Sep 5, 2010 | 07:20 PM
CKS's Avatar
CKS
Rocket- I hope your not right but you probably are.
PKelly- no thats the 1st thing I looked at. All turns the front sprocket & it looks like front sprocket is loose.
Old Sep 5, 2010 | 07:25 PM
Mike T's Avatar
Mike T
Sorry to hear it,man.Pretty big job.
Old Sep 6, 2010 | 03:34 PM
CKS's Avatar
CKS
Well I may have lucked out, The trans. pully nut had worked loose & it stripped the teeth in the pully, I said MAY HAVE, The only problem is it looks like it buggered the starting thread on the shaft a little. So if im really lucky (which is usually not the case) I may get by with changing the pully, nut & lock ring. if anyone has any advise on fixing the starting thread i would really appreicate it.
Old Sep 6, 2010 | 04:38 PM
mrtac2man's Avatar
mrtac2man
get a die set and try to clean it up?
Old Sep 7, 2010 | 12:39 AM
parts eeter's Avatar
parts eeter
File threads with a quality appropriately sized thread file.
Old Sep 7, 2010 | 06:32 AM
PKellyMc's Avatar
PKellyMc
Yeah, jewellers files, a magnifying lamp, and some patience. Good luck.
Old Sep 11, 2010 | 12:09 PM
CKS's Avatar
CKS
Well I got lucky, Chased the threads on the output shaft, Filed a little with small files & parts arrived yesterday, So it wasn't to bad. 1 week down & $153.00 (pully, nut, lock ring & primary gasket set)& 6 hrs total Hrs & were back on the road today.
