changing cam without head work
Old Sep 8, 2010 | 09:19 PM
kmontague's Avatar
kmontague
Default changing cam without head work
just curious of your opinions if its a waste of time and money to just change cams without doin headwork.
Old Sep 8, 2010 | 09:36 PM
07 dyna man's Avatar
07 dyna man
its a pretty good bang for the buck with your 2 into one with a good low to mid rang cam you should see 10hp and 10 tq check out the woods tw6-6 or the andrews 37h
Old Sep 8, 2010 | 09:37 PM
xxxflhrci's Avatar
xxxflhrci
The bottom end power gains were well worth it to me.
Old Sep 8, 2010 | 10:25 PM
red devil's Avatar
red devil
It will give you a good bump in power! If head work is in the distant future, look for a cam that works well in both applications. Woods tw6 & Tman 590 come to mind.
Old Sep 8, 2010 | 10:37 PM
greenyetti's Avatar
greenyetti
Been wondering the same thing myself, I look forward to reading all the info, and how it applies to 88ci carb'd bikes too.
Old Sep 8, 2010 | 11:31 PM
JimmieJack's Avatar
JimmieJack
I've also been doing some reading on this subject. I'd like to start by getting the TTS Master Tune - that should hold me over for a little bit. Then possibly some cams and maybe some headwork. I would like to put the cams in myself and follow up with the headwork when I can. Wondering the same as the OP - a cam that I could benefit from right away but would just get better when the heads were done. Andrews 37, SE 204, Headquarter 500's, Woods 6's .... so many choices. Would definitely like to here more on the subject.
Jimmie
Old Sep 9, 2010 | 12:18 AM
mentor70's Avatar
mentor70
my friend did the SE 204 on his 2k Fatboy, and latter did the 95 SE kit and no head work, bike ran decent. Another buddy did just S$S 510 cams, and he was happy with the bump.
IMO,its only a waste if you wanted to go big to begin with. I just big the bullet and bought a whole Head-Quarters kit, no regrets.
If you do the bolt on upgrades right, it will run great.
Old Sep 9, 2010 | 12:23 AM
paul s's Avatar
paul s
It depends on the cam choice, some of them need more compression to work well, something with an early intake valve close like the cams mentioned are worth doing and the Wood TW5-6(37*IVC) or the Cycle Rama575(35*IVC) are two more worth looking at. If you're reusing the pushrods it isn't that much more to change the headgaskets to the .030's, the .25:1 compression bump was worth it to me.
Old Sep 9, 2010 | 05:05 AM
08fxdf43202's Avatar
08fxdf43202
I've heard that up-grading the valve springs is a good idea.
Old Sep 9, 2010 | 06:56 AM
ColdCase's Avatar
ColdCase
good advice.
kmontague, Head work, other than compression, does not necessarily improve things, especially if you ride less than 5000 rpms. Consider head work if going all out, otherwise I think you get little bang for the buck. Adding compression typically doesn't effect max power, but moves the power bump down in rpm where its more useful on the street.
Just changing cams can make a world of difference depending on your choice. In order of bang for buck, IMHO: ride at higher rpm, lose 30 pounds, a decent tune, more displacement, better cam, low restriction air filter, exhaust system... all with decent tunes..
