Loudest Pipe with best power
I posted a thread on here one time asking if someone had dyno sheets to show the power difference between an aftermarket 2into2 system and a 2into1. I wanted to see if there was really this "huge" difference that all the 2into1 fans claimed. Noone ever posted anything other than their opinion with no dyno to prove it. I think most of these guys went from stock everything to a 2into1 with a tuner, free flowing AC, and some of them even cams, and then said "wow, this 2into1 really works!" They would have probably been just as impressed with the difference from stock if they had went with a good 2into2.
That's JMHFUO, and I could be wrong. But, I'm still waiting for someone to post something that proves that a 2into1 is worth more than maybe a couple horspower and a couple pounds of torque over a good 2into2.
Actually, I do remember reading an article in either the horse backstreet choppers or another mag where they did dyno-test some of the top exhaust. Same bike just swapped exhausts. If I find the article online I will certainly post the link.
They make the bike sound like a musclecar - kind of throaty. Makes you think of the old Thrush glass-packs in the '70's.
They still use the disks. This is when when I first put them on:
Here they are now, three years and a few cans of flat black spray paint later. Yes, those are the stock header pipes. I kept the tips chrome:
Drew
the Thunderheader had the best torque of all the pipes i have ever used. and was fairly loud, im on a D&D fatcat with standard baffle,its not that quite and i have plenty of torque.
Im looking for new pipes--I want loud but not with a bad power lose. I have the SE Slips on and while the have a nice sound, they are not loud enough for me.
Ive been doing some research and it seems once you go too loud (usually means shorter pipes) you start to lose power--especially torque.
Ive got it narrowed down to V&H Big Raduis or Big Shots Staggered.
Ive been unable to find a good comparison of them both. Which one is loudest? And is there a significant power difference if the bike is tuned properly?
Finally, should I consider something else?
Thanks!
But they're not cheap, they're not all that easy to install, they demand billet gaskets, I've heard there's some clearance issues with cornering, and they're not all that good looking.
Is there a significant power difference? That depends entirely on how your bike is tuned. Yeah, if you've got it tuned to a razor edge and you're looking for that last little bit of Warp speed, there's a difference.
Too loud? Power loss? Not really. If you're running your bike up to 6,500 RPM on a regular basis, if you're a Drag Strip junkie, if you're looking for that last .001 second of ET? "Loud" may be just what the doctor ordered for you. It's not really 'loud' it's just more free-flowing. And that's a whole 'nother subject. Top end power is what those pipes are built for. Ever noticed that when the NASCAR boyz pull into the pits, they keep their motors running real high? Or that when the Pro Stock guys line up at the Christmas Tree, they're around a three grand idle? They're not doing that to attract chicks, they're doing it to keep their motors from stalling. They don't have much low end power. It's all at the high end.
But you and I live in the 'real' world. Our resident Gendarme may not appreciate us launching at 4,000 RPM at every stop light. We don't get to shut down after a ten second elapsed time banzai run down the quarter.
Not how I wanna ride anyway. Boring. Been to the drag strip plenty of times (in my car) and I'm over it. But for those that aren't over it, for those that wanna run 10's or even 9's? That's the place to do it, not on the street.
I wanna ride in the countryside, putt around in town, enjoy the scenery at the Beach, go on reasonable trips with my buds and just -- Enjoy my bike.
re: Your two choices -- Which one is loudest (louder
)? They're both about the same. Both of them are about an 8 on the 'loud scale.' Which one makes more power? Neither has a significant advantage over the other, power-wise.And yes, you should always 'consider something else' whenever you're looking for exhaust. Always. You decide on what you want your bike to do, how you want to ride it, then get your pipes and work backwards from there. But I'd say your two choices are pretty good. V&H is a fine bang-for-the-buck exhaust system. And since Andrew Hines is Harley's top driver and current (I think) holder of the NHRA Motorcycle Pro Stock crown, I'd say that V&H might have some insight on what makes a Harley run good.
Are they the best? Almost certainly not. Because there is no 'best'.
Life's a compromise, remember?
You say V&N loose alot of torque. What is your idea of alot of torque. Give me a number. 3,4, or 5 foot lbs. How much? A lot of people don't like those ugly azz 2 into 1 pipes including me. Don't bash **** unless you can post up facts to back your comments. If you loose just a few lbs of torque then that ain't ****. I would rather loose 10 lbs of torque then sport those ugly azz 2 into 1 pipes.
