Fat Bob Intermittant Electrical Power loss
Old Sep 17, 2010 | 04:28 AM
Doodles's Avatar
Doodles
6th Gear
Default Fat Bob Intermittant Electrical Power loss
Hi all,
Over the past few weeks I've experienced 3 occurences of total electrical power loss.
The first time I went over a very small bump in the road at 10mph and everything died. The last time was yesterday when I stopped for petrol. Went to start it again and got some ticking from the starter solenoid and then everything switched off. No lights lit on main panel. Switched off the main switch and back on again, a few seconds later, thepanel lights flickered into action and I was able to start the bike again.
Took the bike into my local dealer (it's only 4 months old), they couldn't find anything wrong. All battery terminals were connected ok. The only proof of the issue was that the time display was flashing.
It's a very intermittant fault. Most days, the bike is fine. Any ideas?
Old Sep 17, 2010 | 06:00 AM
SteveO-ll's Avatar
SteveO-ll
I had it happen with mine also.............and occasionally it would flat spot on initial cranking of the motor before starting............
The only thing I did was, replace the positive lead bolt as it was not making proper contact with the battery post. I/you could see some traces of carbon arcing on the original bolt. No Problems since
Old Sep 17, 2010 | 06:18 AM
Doodles's Avatar
Doodles
6th Gear
Cheers Steve-O. Will give that a bash this weekend. Nice one!!
Old Sep 17, 2010 | 09:37 AM
Ratbob's Avatar
Ratbob
Doodles,
Check the chassis ground connection as well. I believe I saw two different ground studs under my seat, near the bottom of the rear fender.
Old Sep 18, 2010 | 05:37 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Flakey ignition switch, maybe? Intermittent connection somewhere.
Old Sep 18, 2010 | 12:09 PM
jss1975snow's Avatar
jss1975snow
My buddy's sportster would do that, I rode it and noticed the key switch was loose plus he had alot of weight on his key ring, tightened it up, dropped some key weight and no problems since.
Old Sep 20, 2010 | 01:38 AM
Doodles's Avatar
Doodles
6th Gear
Thanks guys. That's given me plenty to check. I'll report back with my findings!
Keep Safe!
Doodles
Old Sep 20, 2010 | 11:44 PM
HD4GD's Avatar
HD4GD
My 2008 Low Rider had same problem. Start/Run Switch bad. Dealer replaced and within weeks replaced on several other bikes.
Good luck tracking it down!
Old Nov 4, 2010 | 07:28 AM
Doodles's Avatar
Doodles
6th Gear
Ok, turned out to be the battery earth connection. Was ever so slightly loose. Tightened up and no problem since. Thanks everyone.
Old Nov 4, 2010 | 09:38 AM
Ratbob's Avatar
Ratbob
Thumbs up Thanks for following up!
Thanks for following up with the solution Doodles, far too often we forget to do that. Feels good to find and fix a problem that the dealer couldn't, huh!
