Red Key Light came on while riding?
Old Sep 17, 2010 | 02:20 PM
QehQeh's Avatar
QehQeh
Originally Posted by HATZO1
... 61121...
This is actually b1121 - the "6" is actually a "B"
Old Sep 17, 2010 | 02:25 PM
gdeese's Avatar
gdeese
just talk with my local shop any pn is a part # which for me is they said is whole speedo i have not done nothing but change fluids tires and slipon screamin eagles me iam just going ride
Old Sep 17, 2010 | 02:26 PM
HATZO1's Avatar
HATZO1
Really, sure as hell looked like a 6 but ill accept that answer.
That would make it this : B1121(TSM) Left Turn Output Fault
Interesting?
Thanks everyone for there input
Old Sep 17, 2010 | 02:31 PM
06hdsb's Avatar
06hdsb
Had the same thing happen to me a few years ago. Found that one of the rear turn signal wires running under the rear fender had rubbed on the tire and was shorting out. repaired wire, secured it and it has never come back on.
Old Sep 17, 2010 | 02:38 PM
HATZO1's Avatar
HATZO1
Dude!, I just went and looked under my rear fender and the wire is hanging down on the left side and has been rubbing on the tire. Crazy stuff. LOL
Thanks again everyone.
Love this forum...
Old Sep 17, 2010 | 02:43 PM
gdeese's Avatar
gdeese
mine does not do like op i just got curious and see if any codes plus i have no problem with speedo i have gone through those moblie speed posters and speedo shows same speed and everbody has condensation in lense
Old Sep 17, 2010 | 02:51 PM
rbartick's Avatar
rbartick
Originally Posted by domenicp7
Its throwing a code check to see what it is. Do a search on retrieving diagnostic codes tons of info.
I thought that codes were shown on the yellow check engine lamp? He said the security light was coming on.
Old Sep 17, 2010 | 02:57 PM
Tom Ricci's Avatar
Tom Ricci
Happened to me once at around 5K miles or so, didn't investigate it then. Bike now has 27K miles on it, hasn't happened since and have had no problems like those discussed here. Key light flashes when it's supposed to and doesn't when it shouldn't.
Old Sep 17, 2010 | 03:35 PM
06hdsb's Avatar
06hdsb
Glad You found it.
Old Sep 17, 2010 | 06:22 PM
QehQeh's Avatar
QehQeh
The yellow engine light shows that the P (ECM/ICM Electronic Control Module) is throwing a code. The red key light shows that the S (TSM/TSSM Turn Sig/Security Module) is throwing a code. I'm not sure what shows when you have a SP (speedometer) or T (tackometer) code.
Anybody?
