Primary fluid-How to tell?
Old Sep 25, 2010 | 03:15 PM
megawatt1's Avatar
megawatt1
Default Primary fluid-How to tell?
I've read various amounts for refill capacities. Service manual say approx 24oz. Also, it states fluid should be at bottom of diaphram plate. How do you tell when the bottom of plate is BELOW the bottom of derby cover opening. Can't see with a flashlight due to the fact that clearance is very close. It's the one thing I do on my scoot that I'm never really sure of. Bike is a 2000 FXDWG. Thanks.
Old Sep 25, 2010 | 03:22 PM
lo-rider's Avatar
lo-rider
Just put in 24 oz.
It's easier to do with the bike on a lift.
Old Sep 25, 2010 | 06:35 PM
CDW's Avatar
CDW
6th Gear
My manual says even with the bottom of the inspection plate with the bike level, TC88. There seems to be many answers to this question.
Old Sep 25, 2010 | 08:02 PM
rocket23's Avatar
rocket23
It is really not a big deal, the oil in question is not under pressure. it pretty much just coats the primary chain, while it is doing it's thing. that said you cannot have too much in it. The oil needs room to work. You can tell simply by leveling the bike. and look for the oil level to approach the bottom of the inspection cover rim. Once you see it your done. Don't fill to the rim edge, thats to much.
Old Sep 25, 2010 | 11:15 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
My 02 FXD is 26 ozs. which works out to the bottom of the clutch pack. Too much oil could cause shift to neutral problems. The newer Dynas take more and so do most of the newer baggers. Drain from the plug, then pop off the chain inspection cover add the oil there. 24-26 ozs., Hey, CW on the older Dynas there are two covers, the derby (clutch) cover and primary chain inspection cover, it sits about two thirds up on the primary cover. That's a lot of oil to add it to the bottom of the inspection cover.
Old Sep 25, 2010 | 11:21 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
If you overfill your clutch will slip.
Old Sep 26, 2010 | 10:55 AM
Mississippirider's Avatar
Mississippirider
Put the 24oz. in and don't worry about it.
04Springer
Aug 28, 2018 11:00 AM
TALLY3
Nov 12, 2012 03:30 PM
jp13
Apr 7, 2010 07:58 AM
GEESE
Oil Archive (no new posts)
Apr 5, 2008 08:20 AM
HDspringer
Sep 23, 2005 09:00 PM
