11" Progressives on a WG?
Old Sep 27, 2010 | 09:42 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
The powers that be in Wisconsin have put in countless hours into giving us the best possible combination of ride quality, stability, and comfort that can be attained without running into other unforseeable problems further down the road. Leave her alone, she looks good as she is. JM2C.
Old Sep 27, 2010 | 09:55 PM
schwangster's Avatar
schwangster
You can get some Ikons that are 1" lowered, and put some heavier springs on them. Adjustable external rebound, internal compression.
I got stock shocks and added the next heavier springs for 2-up riding (when I hit 230# and the 'passenger' was 165#)
Good shocks and you can order them for your weight. Good price.
PM me for more info. I dealt with Dave in SF and couldn't be happier.
Old Sep 27, 2010 | 10:31 PM
ronimac's Avatar
ronimac
I am at about 300 lbs and I have them on my fxd. I am going to put 12 inch Harley shocks on now. I cant take the hard ride any longer. The 11 inch 412 HD progressive shocks do not work for me.
Old Sep 27, 2010 | 10:43 PM
ak47dennis's Avatar
ak47dennis
Just installed the 412 heavy duties on my 2010 WG, progressive recommended HD's for any rider over 225# they told me not to go shorter then 11.5'' that either the fender will need trimmed or take off the belt guard. After a couple hundred miles can tell you the ride is slightly stiffer set on the lowest setting and I have 3/4 -1 clearance between the guard & fender plus it looks bad ***
Old Sep 27, 2010 | 10:56 PM
wideglidebob's Avatar
wideglidebob
i have the 11in prog 412 looks bad *** i am 210 lbs and i have to tell you if i hit anytype of hole it chars the hell out of me i gave up ride quality for looks, you pay one way or anthother, i would pay 500 bucks all day long to get a good ride with a 11 in look, i also lowerd my front one in
Old Sep 27, 2010 | 11:05 PM
Col.Squirt's Avatar
Col.Squirt
Your 2 cents is appreciated, and I can understand where you're coming from. Lol, I'm also into wrenching on cars, and usually one mod that I did, would lead to me having to do another one that I really didn't want to. BUT, that's whats fun, making it your own, and going through all the headaches and problems.
Ronimac: I am at about 300 lbs and I have them on my fxd. I am going to put 12 inch Harley shocks on now. I cant take the hard ride any longer. The 11 inch 412 HD progressive shocks do not work for me.
The ride was really that bad, huh? Did you have the preload at the highest setting?
ak47dennis: Just installed the 412 heavy duties on my 2010 WG, progressive recommended HD's for any rider over 225# they told me not to go shorter then 11.5'' that either the fender will need trimmed or take off the belt guard. After a couple hundred miles can tell you the ride is slightly stiffer set on the lowest setting and I have 3/4 -1 clearance between the guard & fender plus it looks bad ***
So you went with the 11.5" shocks? I'm actually going to pull my belt guard off, so maybe I would be able to use the 11" shocks. Hmmmmmmmm.....I see a phone call to progressive in my future. Thanks again everyone
Old Sep 28, 2010 | 06:35 AM
glideridemike's Avatar
glideridemike
And really how much actual diff with that 1/2" make? If it makes the ride better I'm betting the visuals of the bike will hardly be perceptible.
Old Sep 28, 2010 | 06:55 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
My '06 with the 11" 412's... (also showing tank lift/shift; 2" front, 3/4" rear lift/shift)
Old Sep 28, 2010 | 07:32 AM
hell hound's Avatar
hell hound
I had 11" 412's on my superglide and they were brutal. I sold them on ebay and went back to stock. They did look good, but you will suffer the ride.
Old Sep 28, 2010 | 09:50 AM
glideridemike
You know I bought some, was going to replace mine with them but decided not to after I heard stories about rough rides.....now my cuz put some 440's on his 71 SG and loved them. Wonder if the 440's would work on my 03 or on the newer WG's?
