Changing primary fluid
Old Oct 7, 2010 | 01:00 AM
bobgv's Avatar
bobgv
Default Changing primary fluid
I am going to replace the primary fluid on my 08 Fat Bob any tips for a newbie and how do you put the oil into the derby cover with out it spilling out. How much fluid do I put in, was toid a quart to 38 0z.s from the dealer. Whats right? Thanks for the help in advance. Ride safe
Old Oct 7, 2010 | 01:58 AM
BlockHead96's Avatar
BlockHead96
1 qt. I use a funnel.
Old Oct 7, 2010 | 02:24 AM
Cowpokey's Avatar
Cowpokey
I don't have one, but they sell a special funnel for filling the primary, HD part # 63797-10
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Oct 7, 2010 | 04:16 AM
Mk1Racer's Avatar
Mk1Racer
I fill mine up to the bottom of the derby cover hole. I have a small funnel that I picked up at Wally-World that has a lip on one side (makes it easier to pour into when it's on an angle).
I use Rotella-T in the primary. ~$3/qt at Wally-World, and it's JASCO approved.
Make sure you've got a T-27 Torx bit for the derby screws, and make sure the bit is seated properly. Read too many horror stories about guys stripping the heads on their derby bolts.
Old Oct 7, 2010 | 05:05 AM
maddghost's Avatar
maddghost
It is one quart of oil, True about the #27 torx bit. Bring your bike somewhere level and place something under the jiffy stand like a piece of wood ( i use two 3/4 inch squares of plywood) to get the bike level. {Be real careful not to let her tip over - of course} and use a flex funnel and just hold the spout up high,it doesn't matter if the oil is running down the clutch pack that's what the oil is for. unless you go out and get the special little funnel HD sells. Good Luck! Ride safe!
Old Oct 7, 2010 | 05:31 AM
ynots's Avatar
ynots
anyone know off hand how much to torque the derby bolts?
Old Oct 7, 2010 | 05:41 AM
The Dean's Avatar
The Dean
Buy a maintnance manual. It is all step by step.
Old Oct 7, 2010 | 07:55 AM
danzio's Avatar
danzio
I've never used a funnel. Put the bike level with a 2 x 4 under the jiffy stand and pour directly from the bottle over the clutch pack.
Old Oct 7, 2010 | 10:07 AM
BlockHead96
Just get one from Wally world or the Dollar store!
Torx screws? I just tighten the down by hand, never had a problem.
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
100 INCH lbs. which is 8.3 foot lbs.
