+1 on the proper seating of the torx..some DA that looked a lot like me did on his previous bike and it took three beers and a lot of cussing to finally get it out.
Originally Posted by Mk1Racer
I fill mine up to the bottom of the derby cover hole. I have a small funnel that I picked up at Wally-World that has a lip on one side (makes it easier to pour into when it's on an angle).
I use Rotella-T in the primary. ~$3/qt at Wally-World, and it's JASCO approved.
Make sure you've got a T-27 Torx bit for the derby screws, and make sure the bit is seated properly. Read too many horror stories about guys stripping the heads on their derby bolts.
I am going to replace the primary fluid on my 08 Fat Bob any tips for a newbie and how do you put the oil into the derby cover with out it spilling out. How much fluid do I put in, was toid a quart to 38 0z.s from the dealer. Whats right? Thanks for the help in advance. Ride safe
Make sure you buy and use a new gasket and a new O-Ring.
Mine's a FXDC so it might be little different, but I kept mine on the jiffy stand and filled it to about where it was ready to overflow. Not quite, but almost. IMO, that's full. They don't all take a full quart. Mine took about 30 ounces. Maybe a little less.
Alternately tighten Derby Cover screws to 84-108 inch lbs. Not sure how critical this is. I used my inch-lb wrench and set it to 100 inch-lbs. It's hard to get a good engagement on the screw head with a right angle tool and a torx bit. I think next time, I'll just use the bit in my screwdriver and torque them by hand. But (hopefully) that will be a while. I got a feeling I'm gonna have to buy new Derby Cover screws when I do it again.
I wanted a new Derby Cover so I put it on when I did the fluid change. It came with decorative, chrome plated stainless screws. I hate stainless. It's too soft.
get some good torqes heads... before you remove your derby cover pop them wiht a punch to loosen the lock tight they will come out faster and easier... also i use ATF in the primary
