Quick Disconnect O-Ring
Old Oct 7, 2010 | 03:46 PM
duffy1's Avatar
duffy1
There is 2 O rings in there it is usually the first one that goes, it is the same size as the drain plug oring, there is a guy on forun here that designed the system and told of the numbers and a cut away . as far as replacing the o'ring it took me 5 minutes with a pick and a snall finger
Old Oct 7, 2010 | 04:05 PM
Joe376's Avatar
Joe376
Yep, done this twice already and used a paper clip both times. Took about 5 mins total.
Old Oct 25, 2010 | 03:28 PM
ferrisorange@gmail.com's Avatar
Stage I
Originally Posted by bikertrashchad
Just wanted to share a simple solution to anyone else who may have issues with a leaky quick disconnect on the fuel tank. Recently, after re-installing my tank after paint, the quick disconnect started to leak...leak pretty profusely actually. Anyway, the Harley dealership tried to sell me an entire new quick disconnect. I insisted that there had to be an o-ring inside the disconnect, but the parts guy swore that there was not. After refusing to spend $58 on a new disconnect, I drained the fuel from the tank, removed the disconnect, and removed the cracked o-ring (the one that the parts guy said did not exist). A quick trip to the local parts store and I found the o-ring for under $1.
HELP! MY FUel TANK QUICK DISCONNECT IS LEAKING ON MY 2000 ROAD KING. i TOOK THE O-RING OUT AND IT WAS BAD. WENT TO HD,. THEY SAID CAN'T BY IT,..HAVE TO BUY THE WHOLE FITTING. WHERE CAN I FIND AN O-RING FOR THE QUICK DISCONNECT ON MY TANK? DONT WANT TO PAY OVER $50 DOLLARS FOR THE FITTING WHEN I ONLY NEED THE O-RING. hven't been able to find one at a parts store.
THANKS
FERRIS ferrisorange@gmail.com
Old Oct 25, 2010 | 06:35 PM
skip3406's Avatar
skip3406
When I did my tank I got that o-ring from my local dealer. The part number is 11323
Old Oct 25, 2010 | 10:42 PM
Mr. Lucky's Avatar
Mr. Lucky
ferrisorange - The answer has been posted several times in this thread already, but here it is one more time. You need a #41 o-ring. You can get a package of 10 from Home Depot for $1.97.
johnjzjz
Vrod Parts
11
Aug 21, 2018 12:07 PM
grbrown
EVO
141
Oct 2, 2015 05:08 AM
alfordjf
Jun 6, 2009 10:09 PM
jdreed520
Aug 25, 2008 04:01 PM
jdreed520
Jul 20, 2008 03:02 PM
