180 Vs 200MM 07 SB
Old Oct 11, 2010 | 07:34 PM
dsiltman's Avatar
dsiltman
JRK is saying if your gonna buy a wheel get a 5.75 instead of a 5.5 width and you won't have to worry about it rounding out.
Old Oct 11, 2010 | 08:01 PM
antman27's Avatar
antman27
I dont think the PM Wrath come in a 5.75
Old Oct 11, 2010 | 08:42 PM
Jarhead08's Avatar
Jarhead08
I was asking about the rimsize not the tire size. Anyone know if my stock mag is the right size for a 200 tire? And what all do I need to fit it? I've already got the 180 setup on the bike now but running the 160 tire that came on the bike. Its brand new.
Old Oct 11, 2010 | 09:38 PM
U-234's Avatar
U-234
'07 Street Bob with widened struts and '09 RK fender. 6in Fat Boy wheel with 200 Dunlop. I have been told (by someone who should know) that a Metzler 200 doesn't bell as much as the Dunlop.
Old Oct 11, 2010 | 11:53 PM
bigmikaele's Avatar
bigmikaele
200 mm with 5.5 rim will fill out the fender fine. Get it real close and no issues with rubbing either.
Old Oct 12, 2010 | 01:09 AM
parts eeter's Avatar
parts eeter
The reality of installing a 200 on a 5.5 rim vs a 180 is all you are doing is ruining the profile of the tire by using a 200 on a 5.5 rim. You need a 6inch rim for the tire to PROPERLY fit. Will it fit yes,should you do it NO. Installing too wide of a tire on a given rim size can make a bike feel like it falls into a corner rather than having a nice and smooth lean into the corner.
Here is a 180 Metz on a 5.5 rim
Old Oct 12, 2010 | 03:44 AM
cramil's Avatar
cramil
hmmm... The Metzler data indicates the recommended rim width of between 5.50" and 6.00" for the 200/50R18 and the rim used for measuremements listed is specifically a 5.50".
http://www.us.metzelermoto.com/en_US/browser/attachments/pdf/2008_METZELER_VTWIN_UPGRADE.pdf
Old Oct 12, 2010 | 04:02 AM
Dingobob's Avatar
Dingobob
Originally Posted by Jarhead08
I was receding to the rimsize not the tire size. Angle know if my stock magazine is the right size for a 200 tire? And what all do I need to fit it? I've already got the 180 setup on the bike now but running the 160 tire that came on the bike. Its brand new.
I think your stock rim is 4.5 so 180 is as wide as you can go on that rim. I ended up running wires inside strut cover and doing away with bracket inside fender and using a captive nut and flush mount bolts.
Old Oct 12, 2010 | 05:06 AM
Tat2u's Avatar
Tat2u
Chill dude.... 200mm on a 5.5" is fine, handles smooth, bead fits on the rim correctly, looks fantastic (avon does anyway), done 8000km's and no probs.
It's all good
Old Oct 12, 2010 | 09:32 AM
bigmikaele's Avatar
bigmikaele
x2
Parts eeter where did you get your data from? Can you provide a link? I would like to see where it states that putting a 200mm metzler on a 5.5" rim only ruins the profile and is not a PROPER fit for the tire?
I run a 200 on a 5.5" rim and do a TON of slow speed maneuvering where my pegs are scraping as well as at-speed leans without any difference in how it "drops" into the corners.
