Rattle at downsift- any tips
Old Oct 17, 2010 | 07:35 PM
twothousandfour-supr-glide's Avatar
Default Rattle at downsift- any tips
Hello all,
I ride an 04 Super Glide, the issue I have is when I downshift I hear a rattle it seems to be coming from the front end, it seems like the headlight is the source but everything seems tight.
Also fmi (for my information) is an oil cooler stock on 04 Super Glides and if so is the temperature actuated, i.e., if everything is cool, no cooler things heat up cooler comes on line?
Thanks for any tips you can offer
Tony
Old Oct 18, 2010 | 04:08 PM
2NAHNTR's Avatar
2NAHNTR
Not sure about the front but I had an issue with the chrome lower belt guard. They get a crack in them and end up rattling like hell, especially sitting still. I am about to be on my third one. Might want to give that a look. Good Luck.
Old Oct 18, 2010 | 06:56 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I'd check the primary chain make sure it's in adjustment. You mention an oil cooler, does it have an adapter plate where the oli filter spins on? If that plate is close to the frame it could be hitting the frame during the downshift. The oil cooler is not stock. Another source of rattles are your heat shields. Snug down the clamps that hold them on.
Old Oct 18, 2010 | 07:49 PM
Thanks for the tips guys, I will check these out soon.
kingomtn
Oil Archive (no new posts)
Apr 3, 2013 10:11 PM
dynarule
Jan 15, 2009 01:57 PM
captchaz
Shovelhead
May 21, 2008 09:20 PM
Z_Stingray
Jun 11, 2007 08:09 PM
Roodog
Jun 9, 2007 01:48 AM
