Fat Bob combo speedometer/tach question
Old Oct 26, 2010 | 03:55 PM
lazy eye's Avatar
lazy eye
Yeah, good idea. I PM'd orbframe and already checked out Zanotti's. They've still got it for 233. I'll post back here if I hear from orbframe.
Old Oct 26, 2010 | 04:01 PM
dustinn3's Avatar
dustinn3
Hope you have better luck than me. I ordered mine a month ago and still don't have it yet. They said it would take about a week.
Old Oct 26, 2010 | 04:48 PM
lazy eye's Avatar
lazy eye
Orbframe said his is still running great. I might have to drop the money for it.
Old Oct 26, 2010 | 04:55 PM
Grendel4's Avatar
Grendel4
The hold up is prolly at the factory. If I had to guess. They gotta set the mileage themselves from what I understand.
I was planning on waiting two weeks, but a month? Yikes!! Just pretend you're three years old and Christmas is right around the corner.
Works for me.
Old Nov 17, 2010 | 01:08 PM
FastGraf's Avatar
FastGraf
Follow up. I ordered the speedo/tach and it came in about 3 weeks later. I installed it myself - plug and play, it couldn't have been easier & took about 15 minutes.
The black face looks sharp.
It picked up and incorporates all the features the OEM speedo had: two trip meters (I use one for miles between fill-ups and the other for miles between oil changes), 6th gear light, low fuel light, low fuel count-down, clock, low oil pressure indicator, fuel injector light, everything the stock speedo had.
It also has a really cool feature: you can set the color you want it to light up at night. I'm using red now but it runs all across the color spectrum and sets the intensity, too.
The smaller sweep of two gauges instead of one has been a non-issue; looking down to see the tach isn't probably the safest thing but its an intuitive scan and the information is quickly picked up when you glance down.
Old Nov 17, 2010 | 01:40 PM
Ben.USMC's Avatar
Ben.USMC
Default How is the Shifting
I've always wonder how accurate is the shifting recomandations from the factory. Now that you have a tach, how accurate do you consider the whole 2@ 15mph, 3@25mph...and so on? At what rpms are you shifting? Thanks ahead of time.
Old Nov 17, 2010 | 02:07 PM
FastGraf's Avatar
FastGraf
The bike "sounds" happiest between 2200 - 3500 and the oil temperatures and MPG reflect that. The factory shift numbers seem to be on the low side, shifting around 2800 whereas I usually shift around 3500 - 4000 unless I'm just tooling around. I'm no expert or "professional driver on a closed course", that RPM just seems to work well.
The rev limiter is spot on, cutting the spark as I reach 5500.
Old Nov 17, 2010 | 02:21 PM
Ben.USMC's Avatar
Ben.USMC
Default Thanks
Thanks for the info Sir.
Old Nov 17, 2010 | 02:22 PM
Ben.USMC's Avatar
Ben.USMC
Is there a reason you've stayed stock. Looks like you have and upgraded bike already, are you planing on staying that way?
Old Nov 17, 2010 | 05:38 PM
WoodyTJ's Avatar
WoodyTJ
For my 2010 FXDF, with a 6 speed) the shifting recommendations in the maual was for the running in mileage only. If I am riding lazy I change up on the 10s (ie into 2nd at 20mph, 3rd at 30, etc) and downshift around the same. If I am looking for quick acceleration, ie to overtake, she still sounds fine at 55-60 in 3rd.
