<.... ..> The other source is from the rear wheel and happens when cornering at speed, but can also be caused by hitting bad road surfaces, when the rubber mounts the engine/trans/rear wheel are mounted on flex sideways. This can affect Dynas and touring models and can be cured with a True-Track kit.
Glad to get some input. I would like to say here that from what I have read the "rear" syndrome is not wobble but weave. And (from what I've read) it can be controlled if you do not panic and is not fatal.
Front end wobble on the other hand (or tank slap in it's extreme) is less recoverable and usually results in the bike going down.
Quite right! I have suffered both and not suffered a spill, but am aware a front end can get away. All three of my V-twins have three stabilizers (Firebolt came from the factory with them) and I have True-Track kits on both the others. They transform both bikes. I have never had front-end problems with my Dyna, but did early on with my Glide. Part of that was tyres (Dunlops 20 years ago were awful), plus the air spilling problem 'dyna rider' mentioned, which I cured with a batwing - probably not an option with a Dyna!
There are two distinct causes of handling or wobble problems. One starts at the front and can be caused by high bars, some windshields, even noise. Buffetting of the windshield or the rider's arms gets transferred into the handlebars. This can also happen when travelling at speed, when high noise levels make the rider
tense arm muscles and hold the bars tight, which can also cause handlebar wobble.
As others have already stated, a change of windshield or bars can cure these problems, or using ear-plugs for high noise levels (the best and cheapest tuning aid out there!).
I believe that one happened to me on the way to Street Vibrations, when that pesky deer cleared my front tire by 3-5 feet, at 70 MPH! Wasn't a fun feeling, but it happened so fast, I don't remember if I was on the brakes hard with a death grip on the bars! Or on the brakes at all till after the fact, that's how fast it happened...
BD33 I went from mini apes or buck horns (stock bars) to a set of touring bars from an FXDC. The front is very stable now. I'm sure a set of drag bars would produce the same outcome. Not sure about the pull back drags from places like Carlini...http://www.carlinidesign.com/handleb...ersweep125.php
pre 09 Dynas mostly the super and low rider suffer from this.I know of several that this have happened to. My riding partner had it happen twice with me.Once at 50+ and another time going thru some 20mph switchbacks. Off the road both times and saved it.The desers from the same era also do it.You guys that think it's just tires or bars are fooling yourself.We took the low rider this happened on apart from front to rear replacing all bushings and bearings only to have it happen again.And yes tires,brands of tires,springs and fluid in the front end also. True-Trac solved this problem.
Glad to here the TT solved the problem. Hard to understand how your friend on the Low Rider managed to find himself in a death wobble at 50 mph and on 20 mph switchbacks. This is generally a higher speed issue.
I suppose a TT could help improve stability if he was having an issue with the bike, but it sounds as though either there is/was something really wrong with the bike or perhaps human error in how he approached the turn and then tried to correct it.
Thanks for the info on the bars and how it improved the stability. I'm thinking about changing my bars to a Flanders cafe or flat track style bar as I think it will create a bit more of an aggressive riding position.
Lack of experience, crazy mods, going way to fast, low air pressure. Nothing to do with alignment. Alignment on a Harley is alignment of rear tire to transmission (for the belt) You align the front tire when you move the handlebars or lean. Its called steering. Been on some WV mountians and 20 was too fast for some of the curves.
The dreaded wobble, turned tank slapper. it can happen to anyone at anytime. Recovery chances, slim to none, but possible. Once that hinge in the frame and forks gets loose its over.
My 06 never tracks off in the front. You can feel the rear weave on some curves but not very much. My front end is so solid you can let go of the bars at 70mph and it tracks very straight. Never any wobble and I have had it to 110mph.
