Crossover = Useless
Old Dec 10, 2010 | 10:51 AM
SC-Longhair's Avatar
SC-Longhair
Default Crossover = Useless
I was just outside having a smoke when a thought occurred to me. (Stand back).
It doesn't seem logical to me that having a crossover on our FI one-piece tanks makes much sense to me. It's one big tank, and to be honest I think the crossover just gets in the way and makes it a P.I.T.A. to remove the tank when doing major work to your bike that would require tank removal.
On the older two-piece tanks, yes , it makes sense.
Old Dec 10, 2010 | 11:24 AM
rdondes's Avatar
rdondes
So can anyone verify whether the cross-over actually does anything or if it is useless?
Old Dec 10, 2010 | 11:27 AM
Len's Avatar
Len
anyone? Bueller? anyone?
Mike Horrell's Avatar
Mike Horrell
My bike's not here at the moment, but are there two internal fuel pickups? The one-piece tank
straddles the upper frame tube so unless there are two pickups inside the tank, how would
you get all the fuel out of each lobe?
Old Dec 10, 2010 | 11:28 AM
redmonster13's Avatar
redmonster13
it would allow the fuel level to equalize one the level drops below the tunnel, that is only thing I could come up with and I am just guessing here.
Mike beat me to it.
Old Dec 10, 2010 | 11:48 AM
Just Enough's Avatar
Just Enough
I think if you have a front tank lift installed you are correct, the crossover would not be needed. With a stock setup under a steady highway cruise when you get near the bottom of your fill the right side might not transfer the last half gallon or so without the transfer tube.
Old Dec 10, 2010 | 12:14 PM
SC-Longhair
Now I'm just thinking out loud here.
Wouldn't the fuel seek it's own level, much like water does with or without the crossover? If there is forward motion, wouldn't that cause the fuel to slosh around, thereby possibly forcing it to move around and quite possibly to the fuel pickup?
Old Dec 10, 2010 | 12:20 PM
Robbie13's Avatar
Robbie13
LOSER
I could see where it might be useful if the tank set level/stock. I was thinking about the same thing the other day when my tank lift came in. With front raised up, the back of the tank will do the equalization? If that makes sense.
Old Dec 10, 2010 | 12:46 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Vic,
Not sure if you run a tank lift. What about this experement to find out:
use a vise grip
and close the cross-over tube when the fuel level is almost at the lowest point.
Now keep on riding untill you have to change to reserve. At that point remove the vise grip to find out if the fuel in the tank levels from r/h to l/h side...
Old Dec 10, 2010 | 12:58 PM
SPECIAL ED's Avatar
SPECIAL ED
Nice idea but FI tanks don't have reserve at least mine doesn't
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
