Crossover = Useless
Old Dec 10, 2010 | 11:03 PM
blacknsilver's Avatar
blacknsilver
I just cut the hose and install a new one when needed. It's only about $3 for a new one. The quick disconnects I saw were about $40 so I could buy a lot of hoses for that.
Old Dec 11, 2010 | 07:43 AM
SC-Longhair's Avatar
SC-Longhair
Originally Posted by 8541hog
Vic, my Uncle always said "When one doesn't think so good, one shouldn't think so much" ... LOL
So is there any reason why you could not have a quick disconnect on the right side like you have on the left, with a wye in the fuel line?
Was actually thinking about this the other day when I was thinking about building a custom tank.
lol Yeah, I've thought about the quick disconnect deal but my idea was more towards the "why do we still have this, since it's a once-piece tank" rationale. If there truly is an issue of fuel getting from one side to the other, why not have to pickups inside the tank.
Old Dec 11, 2010 | 08:05 AM
8541hog's Avatar
8541hog
Only reason I can think of for not having two pickups is if one side went dry you would have that side sucking air which could be a possible issue for pump operation.
Old Dec 11, 2010 | 08:20 AM
Wireguided's Avatar
Wireguided
I AGREE With 8541
Old Dec 11, 2010 | 08:25 AM
8541hog's Avatar
8541hog
Now that I think about it, having 2 QD's would not solve the issue either, as it is a fuel pump, not gravity feed like a carb tank. Somewhere you have to have a crossover for an EFI setup with an internal pump.
Old Dec 11, 2010 | 09:27 AM
bobnehoc's Avatar
bobnehoc
I was thinking about the same thing a few months back. What is the purpose of the cross over tube on a one piece tank? The old Fat Bob tanks made perfect sense but not the new ones. I asked my brother the same question and after a little discussion we believe it is due to the tunnel in the tank. Not having a flat bottom you need a way to get the gas to flow from the lowest point in the tank to the other side (LeftSide) where the fuel line is . As the fuel level drops the cross over helps keep the tanks equal allowing most but not all of the gas to flow from the right to the left. As far as putting a quick disconnect on as some have stated that would be a good idea as long as it is cheap. I would not spend more than a few dollars on a quick disconnect as I would rather spend it on other mods instead, besides how often do you really pull the tank anyway? I do all of my own wrenching and in the last few years I have only needed to remove my tank once when I changed my Rocker Covers to Black ones on my old SB.
Old Dec 11, 2010 | 09:39 AM
Faast Ed's Avatar
Faast Ed
Originally Posted by Just Enough
I think if you have a front tank lift installed you are correct, the crossover would not be needed. With a stock setup under a steady highway cruise when you get near the bottom of your fill the right side might not transfer the last half gallon or so without the transfer tube.
I'd hate to have my bike sputter and pop while leaning hard into a high speed curve. It's there for a reason. Not real clear on the science behind it.
Old Dec 11, 2010 | 09:41 AM
Faast Ed's Avatar
Faast Ed
The quick disconnects can leak at times.
Old Dec 11, 2010 | 03:15 PM
NoLongerAmember's Avatar
NoLongerAmember
If I removed my tank as often as I change my oil I would consider it a hassle. Even so, a couple of caps, a rag and a .50 cent crimp clamp does seem like a hassle to begin with. Takes about 5 minutes to drain the tank by powering up the FP at the fuse block FP fuse (not even necessary), clip the clamp, pinch the hose, rag, slide it off, cap the tank fitting, cap the hose, done.
CB
The cross over equalizes the tank.
RJC
Powdercoat & Paint
Jul 26, 2011 05:29 PM
Keith_71
Exhaust System Topics
Feb 27, 2009 07:01 PM
bartles
May 15, 2008 12:31 PM
friknjok
Feb 12, 2008 09:05 PM
Omen
Jun 5, 2005 02:14 PM
