Easy Alignment Tool
Old Dec 19, 2010 | 05:00 PM
R_W_B's Avatar
R_W_B
Post Easy Alignment Tool
I was frustrated with the HD manual method of setting my rear alignment so I came up with these simple cheap items to make it easier, and more exact. I have a written explanation of the items and how I used them in my Tools and Tips album, just go to my profile at
https://www.hdforums.com/forum/membe...reference.html
Old Dec 19, 2010 | 05:09 PM
icecaps's Avatar
icecaps
Reading More Posting Less
You might want to check out Mud's version if you feel like making one.
https://www.hdforums.com/forum/6967986-post1552.html
Old Dec 19, 2010 | 05:18 PM
R_W_B's Avatar
R_W_B
Smile
Originally Posted by icecaps
You might want to check out Mud's version if you feel like making one. https://www.hdforums.com/forum/6967986-post1552.html
No thanks on that. Mud has helped me before and he is an Ace of mechanic stuff. But making a tool like his is way more work than my few cheap items and I don't see how it would work any better.
Old Dec 19, 2010 | 07:06 PM
first dyna 07's Avatar
first dyna 07
Excellent Very cool
Old Dec 20, 2010 | 06:11 AM
OldMike's Avatar
OldMike
Thanks for posting, I use a pin like that and a caliper to do mine.
Mike
Old Jan 19, 2011 | 11:43 AM
R_W_B's Avatar
R_W_B
Post Update Even better and cheaper
Even better and even cheaper.
I looked at MUD's tool (which is neat like everything he does) so I figured the axle nuts must have the same flared diameter. So after I had gotten alignment dead on with the magnet method to center of nuts, I then checked the distance on each side from alignment hole to outer circumference of the axle nuts. They are exactly the same dia on each side so you can just use anything to measure them. I now use a brass welding rod with a plastic tie cut to a point I can stick in the alignment hole.
Seems like this is the method H.D. should have illustrated. It's a straight measurement.
Old Jan 19, 2011 | 12:13 PM
misfitJason's Avatar
misfitJason
3.99 and works great
Old Jan 19, 2011 | 12:45 PM
dyna rider's Avatar
dyna rider
Default Axle Alignment
Damn, I just use a piece of a coat hanger with a couple of bends in it...I thought it was a cheap and easy as they come.
Old Jan 19, 2011 | 03:29 PM
rdondes's Avatar
rdondes
I use the two pieces of wire coathanger also - one for each side - the 90 degree bend goes into the little alignment hold and the end of the straight end indicates the center of the axle nut (one for each side). No fuss, no muss.
Old Jan 19, 2011 | 06:19 PM
R_W_B's Avatar
R_W_B
Post
I never could get a perfect 90% bend on that method, although I was doing it with a 1/8" welding rod that was stiffer. A coat hange might have been easier to control.
But in any case I have found (at least on my Dyna) that the dia. of the axle flare nuts are identical so you don't need a bend, just measure straight from the hole to the outermost edge of the nut flare.
peddler
Feb 6, 2014 08:45 AM
dawg
Jan 23, 2012 04:00 PM
MNPGRider
Nov 2, 2010 04:06 PM
ord sgt
The General Motorcycle Forum
30
May 12, 2009 08:34 AM
Johnny
General Topics/Tech Tips
16
Feb 14, 2005 08:39 PM
