8in or 10in t bars?
If you have long arms like I do, I would go 8" as the 10's are that much closer. I enjoy riding with the 8's, but at times I wish they were a tad further forward.
If you have short arms (under 32" sleeves), you may want the pullbacks.
Either 8" or 10" will fit OEM wiring and cables IF you had OEM mini apes.
If you are near or over 6 ft tall you will probably want the 10" T-bars.
If shorter with shorter arms go with the 8" T-bars.
I like the Wild1 brand, they run the 1" bar throughout with the 1-1/4" over it (not just welded to it) and they are 30 1/2" wide which gives better control than the narrow bars.
Again if you are very tall or have long arms (depending on how you like to sit) you will not want any of the bent pull back T-Bars. A friend has 10" straight up T-bars and the grip position is just about exactly where my mini-apes are since I have my mini apes rotated slightly forward (instead of inline with the rake) due to my long arms. I like to sit up straight not lean back or lean forward.
But regardless of what brand you buy I would buy the one unit T-bars not separate risers and drag bars since I have heard that the separate riser setups have a bit of flex in them once you get above 8" high.
Good luck with it.
