To lower or not, FXDWG
Old Jan 24, 2011 | 08:27 PM
SPECIAL ED's Avatar
SPECIAL ED
Sometimes you get some handling issues with lowering just the rear IE. a high speed wobble while cornering but I've found firming up the rear end goes a long way toward fixing this.
Old Jan 24, 2011 | 09:20 PM
ak47dennis's Avatar
ak47dennis
double tap..
Old Jan 24, 2011 | 09:27 PM
ak47dennis's Avatar
ak47dennis
Thanks guys for your input, I do like my bikes LLOOWW but I also like the chop look with rake.With the back end lowered and the angle finder on the forks tubes it reads 40 degree hate to lose that.....it alreadys sits up pretty dam straight on the kick stand.
Old Jan 24, 2011 | 10:12 PM
wideglidebob's Avatar
wideglidebob
I lowered my rear, than did my front it handles alot better plus looks bad ***, but as you can tell there is two camps here
Old Jan 25, 2011 | 04:34 AM
20RoadGlidin's Avatar
20RoadGlidin
I'd leave it alone personally. I think it looks hot as hell the way it is. I love the new style wide glides. I wish I could afford a second bike because I'd get one.
Old Jan 25, 2011 | 07:13 AM
behr54's Avatar
behr54
6th Gear
Originally Posted by blacknsilver
Looks good as it is. I did the same thing.
blacknsilver- nice ride! Just wondering what kind of front forks and tire and wheel combo you have on your bike?
thanks behr
Old Jan 25, 2011 | 08:02 AM
Ovaltine Jenkins's Avatar
Ovaltine Jenkins
Level unloaded isn't the same as level with you or you + passenger on the seat. I'd say sit on the bike with it upright and your full weight on it and check again.
I mean, it looks just fine now. But what about while going down the road?
Old Jan 25, 2011 | 10:28 PM
wideglidebob
lower it
Old Mar 19, 2011 | 07:58 PM
ak47dennis's Avatar
ak47dennis
Decided to install the progresive drop in kit, its been sitting on the work bench...anyway install was simple took less then an hour and the springs are of a much higher quality then the factory HD's. Installing the 1" spacers lowered it 1" looking at it seems much lower! I went out for a drive the handling is a lot better with less dive under braking.
Old Mar 20, 2011 | 12:24 AM
Ridaho's Avatar
Ridaho
Leave it! Back end slammed looks great!
