Yes, another ticking thread
It kinda sounded like something was hitting something, like a rattle (more than a ticking), and it obviously changed speed as the bike did. That's why I orginally thought something had come loose in the horn due to it vibrating so much.
Sometimes, when someone knows they got to get rid of a car/motorcycle/boat they can get a little 'disinterested' and cut corners. Whenever I buy anything used, I don't care if it's lawnmower, I change the oil AND the filter just make sure (like you need another chore with a new house). That way, I also know what's in it. The original owner's favorite oil might have been Louie's Bulk oil. Ya never know -- Or, he might have got just a tad lazy or had to re-paint the bathroom and decided not to change the filter. ??
Get some good oil, a Harley filter and make a mess all over your garage like the rest of us. I prefer a GOOD synthetic. Hundreds of opinions on which one is best. My stock oil came out at 400 miles. To hell with Harely's "break-in" period. Bunch of nonsense IMHO.
If it's pretty cold where you live right now, that could/would be adding to the ticking noise. Ticking? Meh. A hard-metal knock? Worry.
Change the oil and the filter and see what happens. Cheap, and it'll give you some peace of mind.
P.S. Harleys make unusual noises.
P.P.S. It's a Dyna. Most of them really don't take 3 qts of oil. Start with a little less than 2 1/2. Word. While I'm at it, buy and USE the $.99 O-Ring
It could've been coming from the primary but it did seem quite high, hence the reason for thinking it was coming from the horn.
Not sure if I'd describe it as a knock but it definitley sounded like metal hitting metal, but then again this morning it was hardly there! So weird.
I'm used to the harley ticking sound as I used to ride a sportster. Maybe she was just in a bad mood!
We'll see.Thanks again.
I put my windshield on for the first time this year couple weeks ago and noticed a 'ticking'. Didn't pay a lot of attentiion to it 'cause I know the bike motor is sound. Took the windshield off because it got up into the low 80's down here and the ticking went away. Put it back on (it got down into the 60's) and back comes the ticking. Meh.
It could also be a loose gas-tank bolt. But I'll respect your mechanical ear and assume it's the engine. Probably is. Change the oil and filter and keep an ear open.
Good luck.
edited to add: Most people don't realize how long it takes a cold Harley air-cooled motor to get up to operating temperature. Even though it's air cooled, it takes some time. Twenty minutes on a 75* day, longer at lower temperatures. Sometimes much, much longer if it's so cold ya got icicles hanging out your nose. Don't discount that either.
Good luck.
