Newbie
Old Feb 14, 2011 | 04:14 PM
oldbaldjay's Avatar
oldbaldjay
4th Gear
Talking Newbie
Hi im new to this forum and harleys im looking at buying a 2001 dyna glide, is there anything i should be looking out for when inspecting a possible purchase?
Thanks J
Old Feb 14, 2011 | 04:31 PM
Iceman24's Avatar
Iceman24
Greetings & welcome from NE. Best thing to do when looking at used bikes & go over it w/fine-tooth comb. Look for signs of being dropped (i.e. scratched handles, pipes, pegs, etc.) and ask for maint records. On first look you'll know if the bike's been taken care of...if it looks like crap (faded, chipped, worn, torn) - probably not one to buy. Good luck!
Old Feb 14, 2011 | 05:28 PM
SouthpawHD's Avatar
SouthpawHD
And be sure to take it for a ride - longer than 10 minutes. Pay attention to how it sounds, how the throttle response is, how it feels on straight road (it should track fairly straight), etc...
Also look for signs of leaking. Look under the frame for signs of sludge buildup caused by leaking oil. Look at the gaskets around the base of jugs and around the tranny. Generally, you'll know if it's leaking.
Good luck.
Old Feb 14, 2011 | 06:33 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
How many miles on it? This will dictate cam chain tesioner shoes inspection/replacement. These are wear items. Also the outer been changed to a roller bearing on the rear cam and ball bearing on the front cam. Has the previous owner already dealt with this? Otherwise a nice strong bike.
Old Feb 14, 2011 | 11:11 PM
ZUTEDUFF's Avatar
ZUTEDUFF
howdy from Arkansas and welcome to the forum... what they said>>>
Old Feb 14, 2011 | 11:36 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Since you are new to Harley's go to the Harley Davidson website and using the dealer locator find and call your local dealer service department and see how much they would charge to do a mechanical inspection of the bike. I have seen some charge 1 hour labor ($80) and give you a written evaluation.
That way you won't get screwed over if there is any real issues.
BTW, welcome to the forum.
Old Feb 15, 2011 | 04:45 AM
bikenut1957's Avatar
bikenut1957
+1 on what they said. Take your time. It took me about 3 years of looking to fine my soul mate bike.
Old Feb 15, 2011 | 08:50 AM
NeverEnoughToys's Avatar
NeverEnoughToys
+1. As a first bike, that $80 could save you thousands. Worst case scenario is that $80 gives you peace of mind
Old Feb 15, 2011 | 04:22 PM
oldbaldjay's Avatar
oldbaldjay
4th Gear
hi all thanks for your replies, im in the uk the bike has about 15000 miles on the clock, very clean from what i saw and a test ride is booked for this friday
Old Feb 20, 2011 | 04:27 PM
oldbaldjay's Avatar
oldbaldjay
4th Gear
The test ride has been postponed the bike needed a new battery and by the time it was fitted it was to late. The the weather turned sour on saturday, . Hopefully the ride will take place this weekend sometime weather permitting.
