PC111 users
Old Feb 19, 2011 | 08:17 AM
ric306's Avatar
ric306
Default PC111 users
when you installed your pc111, where did you put the unit? was it a pain in the a--? had any problems? 2008 FXDC. thanks ric
Old Feb 19, 2011 | 08:23 AM
davidc's Avatar
davidc
Get a PC-V its much smaller
Old Feb 19, 2011 | 01:41 PM
ric306's Avatar
ric306
ttt sure would like to know.
Old Feb 19, 2011 | 02:02 PM
vmax94's Avatar
vmax94
They have installation instructions on thier web site that helped me alot.
Old Feb 19, 2011 | 02:09 PM
cornishman's Avatar
cornishman
As you say it is a tight fit. I wanted mine at the top facing me so any adjustments were easy and it would be well out of the way of any water, dirt. To help matters i cut all the tie wraps and plastic locators that hold all the electrical components. this let me move things around and create space for the PC111 at the top, lying flat facing me. As i said a little fiddley but it will go, a big dose of patience/beer also helps.
Old Feb 19, 2011 | 03:42 PM
Supermachine's Avatar
Supermachine
take the battery and box out.. it will help ALOT
mine is located where the factory security module goes, i fought it all night trying to get it into place.. next night took the battery out and it worked much better. the junction is where you'll have the most problem. mine is zip tied to the front edge of the square backbone that runs bahind the rear exhaust pipe. 3500+ miles with no issues. had it programmed by fuelmoto before install, so saw no need for accessibilty as i won't be changing it until after bikes out of warranty
Old Feb 19, 2011 | 09:10 PM
HemiOrange's Avatar
HemiOrange
Mine's under the seat. I had it behind the electrical caddy, but my indie put it under the seat. I'm going to leave it there.
Old Feb 19, 2011 | 10:19 PM
PigInaBlanket's Avatar
PigInaBlanket
Mine is under the seat on it's side.
cmosentine
Jul 23, 2011 10:01 AM
JustDennis
Touring Parts
Jun 27, 2011 06:40 PM
JGraham
Apr 7, 2011 11:28 AM
Dark Horse
Jul 15, 2010 11:23 PM
fathertime
Jun 12, 2010 09:23 AM
