What happened?
Old Oct 9, 2006 | 08:25 PM
mnblaster's Avatar
mnblaster
Default What happened?
Went riding with a friend over the weekend. He was in the lead on his 89' Lowrider when the bike started to miss and eventually quit running. The headlight was still lit but dim when the ignition switch was in the "on" position but the battery didn't have enough power to crank the engine. We were able to get the engine to crank after a charger was on it for a while. Is this a charging system failure? Couldn't find any other obvious problems.
Old Oct 9, 2006 | 09:00 PM
Z's Avatar
Z
Default RE: What happened?
Sure sounds like the charging system to me. Did it die again after riding it a while after the charge? If so, I'd definately suspect charging.
Old Oct 9, 2006 | 09:19 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Sounds like the charging system. with the motor running and lites on a volt meeter on the battery terminals should read around 14 volts
it could be corrorded connections on the battery or elsewhere
Old Oct 10, 2006 | 12:34 AM
mnblaster's Avatar
mnblaster
Thanks for the responses, the bike went in to the shop today, I'll post the results.
Old Oct 10, 2006 | 12:02 PM
soup48's Avatar
soup48
How old is the battery, you could charge it again and see wait the voltage drop is when cranking. It sould not be below 9 volts fi lower the battery is bad or you have a starter that is going out. Check all the wire connection from ground and on the starter.
Old Oct 10, 2006 | 09:56 PM
mnblaster's Avatar
mnblaster
Just found out that it was the voltage regulator.
Eric T Holmes
Electrical/Lighting/Alarm
Apr 2, 2019 04:17 PM
windy blue
Sep 22, 2017 04:16 PM
bradorr
Ironhead
Jun 28, 2012 05:39 PM
ScooterJammer
Apr 28, 2008 04:55 PM
