Calling all Wrenches - Electrical Problem
Old Apr 28, 2008 | 08:47 AM
ScooterJammer's Avatar
ScooterJammer
Default Calling all Wrenches - Electrical Problem
While riding home over the weekend, I noticed my headlight cycling dim and then bright.When the headlight dimmedit seemdtheengine was missing. The battery is old (at least two years), so I'm going to start with the simplest thing and change that out and then work my way to the more intrusive stuff. My initial thought is a Coil going bad, but at this point it's only a guess. I know this isn't very much information to go on, but it's all I have at the moment.
I sure would like any thoughts from the "technically savy" memebers of the HDForum.
Thanks in advance.
Old Apr 28, 2008 | 09:07 AM
TexasRedneck's Avatar
TexasRedneck
Default RE: Calling all Wrenches - Electrical Problem
Unless it's shortly (badly) internally, a coil won't create the symptoms yer describin'. Sounds more to me like either a short, a battery goin' bad, or a problem with the chargin' system, such as a regulator stickin', causin' the system ta run off the battery fer a bit.
Old Apr 28, 2008 | 09:33 AM
twincam47's Avatar
twincam47
2 simple things first...
make sure the ground cable from the battery is tight at the starter...it uses one of the starter mounting bolts...this is a common problem.
next...check the regulator ground wire....it is located beneath the right transmission side over and has an eyelet end using a bolt in the transmission. if this one is loose it will not allow the charging of the battery.
Either of these will prevent the charging system from putting power back into the battery.
your symptom is classical for the motor running off of the battery only...Once the battery starts draining from no charging or can not hold a charge...your motor will act as described. Low electrical power to the injectors causes the hit and miss....they will not spray correctly.
You can put a volt meter on the battery with the engine running....at about 2-2500 rpm you should see in excess of 14VDC......If you get those numbers I would then think it was the battery......not accepting the charge or intermittent charging. The service manual outlines several procedures for testing the stator and then the regulator.
Old Apr 28, 2008 | 09:49 AM
tailgater's Avatar
tailgater
I agree with Red. Coils don't give trouble often. When they do your bike will just quite running, may start after cools down, backfire, engine miss or all of the above. It sounds like you may have a loose ground or bad battery connection. When the connection is not made the chargeing system has to pull the lights plus the engine, I.E. engine runs ruff and lights dim. Let us know what you find. Luck to you.
[align=left] [/align]
Old Apr 28, 2008 | 09:56 AM
liltrk's Avatar
liltrk
ORIGINAL: twincam47
+1
Also a two year old battery is not old, I replaced my first on at six and it was still working.
Old Apr 28, 2008 | 12:11 PM
ScooterJammer
I plan on performing all the suggested checks including the battery load test as outlined in the manual. The statement above is interesting. When I installed my mounting bracket for the 2 into 1 pipes I installed I remember the ground wire eyelet was too small for the bracket mounting bolt and I know I just forced it. So, I may have induced my own problem.
Thanks to all for the trouble shooting tips. HDForum is a great resource!
Old Apr 28, 2008 | 04:55 PM
Sharknose's Avatar
Sharknose
ORIGINAL: ScooterJammer
You're probably on to something. One of the best pieces of amateur wrenching advice I ever got was to check the last thing that was changed, no matter how unrelated it might appear on the surface.
lefty33
Electrical/Lighting/Alarm
Sep 5, 2018 11:03 AM
aacciainoli
May 24, 2018 02:14 PM
Pfarley1
General Topics/Tech Tips
50
Jul 29, 2017 08:42 AM
ssbogger77
Jun 3, 2017 08:56 PM
d59s67
Jun 23, 2007 10:51 AM
