Help,,,wiring rear lights
Black, grey, red and white, blue, purple and a orange and white. The black is just a ground and is split off into three for the left sig ,right sig and licends light.
I found through another member (thanks turbostang) how everything is suposed to go.
Left sig gets a black ,and the purple
Right sig gets a black and the orange and white
licends light gets a black and the grey wire
I wired the licends light first, it worked
Nexted I wired the plug for the left sig and its worked ,run ,turn ,stop
Then I noticed I did a crappy job making up one of the plugs so I redid it.
Now for some reason the left sig will not come on. I used a test light and checked the purple wire all the way to the other side of the run,turn ,stop module. I got no power now. The right signal light comes on but just in run mode,it will not blink for the signal or get brighter when I hit the brakes like the left side did earlier.
Are there other fuses besides the ones under the cover on the left side?
https://www.hdforums.com/forum/6231956-post1.html
from my ***Dyna Models Wiring Diagram Links Index***
The traced the wire (purple signal wire) back to the turn signal security module on the wiring diagram?
Does anyone know where the turn signal security module is on the bike?
