There's a thread in these forums that a member started a while back where he put out a diagram showing about 4 different drag bars and where their location would be compared to an FXDC stock bar. It's a great diagram...really help you to envision all the locations. I've attached it to other threads in the past, and bumped once too.
I can't search too well for threads on my cell phone, or I would find it for you. Do a search for 'fxdc drag bars' and I think it comes up toward the top. Good luck.
Being that we are both the same height, I'd go with 4.5" to 7" rise and no more than 8" of pullback with 28" to 32" of handlebar width.
I had the best handling with 4.5" risers w/1.5" pullback along with 27.4" wide drag bars with 3.5" pullback. No cable change, but the brake line was way "S" shaped. With this set-up, wider bars would have even been better, perfect for me.
Instead, I went next with 8" (1.5" pullback) risers and 31" drags (3.5" pullback), I lost the tight handling, but the cables fit fine. However, in addition to the loss of finesse, the compounded height, 4 (or 5) piece bar conglomeration and sloppy rubber bushings caused a handlebar alignment nightmare, not to mention the rubbery bar to fork feel. I then installed poly riser bushings, but I still had too much twisting in the riser/clamp/bar area to feel comfortable with.
However, I did learn that wide bars and low risers were the way to go for all around handling, but I was still reluctant to change my cables, lines and wires. That's when I ordered the t-bars. A happy medium that eliminated my 4-piece arrangement into 1 piece.
So, my t-bars are 32" wide, 7" tall and have about 6" of total pullback. A great fit for me. A better fit would be 5" tall, 32" wide and 6" pullback, but that brake line would need to be tweaked (bent) a bit and my 2" tank lift might interfere with the cables at full lock.
Your proposed 11" pullback/8" rise might fit w/o further mods, but that is a lot of pullback, way more than I'd ever want to do. It might also require lengthening some cables. 8" rise, 6" total pullback and 31" wide bars seemed to put the cables and wires back to where they fit right. Just don't get narrower bars to make the cables fit if you choose 11" pullback
I really appreciate your help Hemi. I have phoned J&P and cancelled the set of Santee's that I ordered with the 8" rise and a whopping 11" pullback. I'm going to have to source something else out as Santee's don't seem to have anything with less pullback.
thanks for the numbers, I'll re-read what you wrote and make a proper decision.
Dene
Keep in mind to get t-bars or drag bars that are wide enough so that you'll be able to see out your mirrors or the only thing you'll see is your shoulders.
That is true. I also bought long stemmed mirrors for a little more rear view.
6.5" tall pullback risers. w 30" drag bars. all from drag specialties. the part numbers are listed in my garage. all stock cables and brake line. stock mirrors work fine, and they are comfortable for all day rides.
Interesting how your brake line from the banjo bolt to the risers follow the contours so well. That will definitely take up the slack. Did you bend them? How? Any more pics from the front?
