Removing tank emblems.
Old Mar 3, 2011 | 04:09 PM
cursedspirit's Avatar
cursedspirit
Default Removing tank emblems.
Hey all,
Am thinking of stripping the emblems on my 2010 SB with Demin black paint. What is the safest and easiest way to remove them?
Old Mar 3, 2011 | 04:10 PM
2011Deluxe's Avatar
2011Deluxe
Heat with a hair dryer then just pull them off. Very easy and fast to do.
Old Mar 3, 2011 | 04:11 PM
DSnoopy's Avatar
DSnoopy
Patience
Heat
Windex
Repeat
Old Mar 3, 2011 | 04:13 PM
nvsteve's Avatar
nvsteve
http://www.flyingsnail.com/Sprung/removeemblem.html
Old Mar 3, 2011 | 09:13 PM
rlcgun's Avatar
rlcgun
6th Gear
mine jumped off on a very cold day
Old Mar 4, 2011 | 04:54 AM
mang0's Avatar
mang0
is there an optimal time to remove these? like in the first year...just wondering if there is ever a color difference after several years like say the rest of the tank fading from the sun....
Old Mar 4, 2011 | 05:48 AM
ratzohio's Avatar
ratzohio
I use a piece of piano wire.Doesn't scratch paint and takes them off fairly quick.
Old Mar 4, 2011 | 06:41 AM
Great Gazoo's Avatar
Great Gazoo
Friend of mine used dental floss - says it worked like a charm.
Old Mar 15, 2011 | 02:12 PM
randog's Avatar
randog
use a heat gun or least a blow dryer. a credit card will help to start the lift. any residual glue can be cleaned up by soaking it with wd-40, then the glue will roll up off the surface like a booger. Fishing line might help cut the glue during the lift as well
Old Mar 15, 2011 | 08:37 PM
Masshole Bobber's Avatar
Masshole Bobber
Just took mine off my 09 Bob. Used fishing line and wd-40. Googone for any left over glue. No discoloring, but make sure you clean the take if remounting new badges. Good luck
89Speedy
Aug 24, 2012 05:58 AM
ct555
Mar 28, 2012 05:46 PM
JTRK2
Jul 31, 2010 02:16 PM
leggz
Apr 9, 2010 02:01 AM
yank
Jul 21, 2009 02:21 AM
