REV Limiter
Old Oct 11, 2006 | 10:10 PM
gto frank's Avatar
gto frank
Default REV Limiter
I read the outher day on this sight about some harleys have a rev limiter do all dynas have this or only some years can someone explaine this it is the first time i have heard about this. thank you very much
Old Oct 11, 2006 | 10:14 PM
DGlide04's Avatar
DGlide04
Default RE: REV Limiter
That's correct. Stock rev limiter is set at 5800 rpm's, if you do a Stage 1 or other upgrade, it'll usually get bumped up to around 6,200.
D'
Old Oct 12, 2006 | 02:06 PM
gto frank's Avatar
gto frank
thanks for the info. i was hoping someone would explaine where the rev limiter is and how it works
Old Oct 12, 2006 | 03:57 PM
DGlide04's Avatar
DGlide04
I could be mistaken, but I think the rev limiter is built in to the ignition module which is under the seat on the left hand side of most Harleys and is not an actual moving part, if that is what you were getting at. It can be reprogrammed to a higher limit via a software and computer link. Like I said, that's my understanding. When it senses the revs at the preset limit, it momentarily cuts off until the revs fall below the set level.
Old Oct 12, 2006 | 04:02 PM
sleepneagle's Avatar
sleepneagle
ECM, Engine Control Module. Chip is programable and stock is set at 5500 RPM's. When you get a stage kit, I, II, or III the chip gets programmend for 6200 R's. Also the PC III reprograms (sets) the chip for more R's
Old Oct 15, 2006 | 02:58 AM
redheadfred's Avatar
redheadfred
yeah , stock is 5500 and stage 1 is 6200
Old Oct 15, 2006 | 03:00 AM
redheadfred
stock valve train is recomended for no more than 6200 with stock springs
Stevo1340
EVO
13
Mar 26, 2020 08:35 PM
motohead20
Aug 21, 2011 04:14 PM
palatium
Dec 7, 2009 07:54 PM
hddave2
Feb 19, 2009 08:34 AM
Chas63
Exhaust System Topics
Dec 12, 2008 02:47 PM
