4000 rpms
Old Aug 21, 2011 | 07:06 AM
motohead20's Avatar
motohead20
3rd Gear
Default 4000 rpms
I have a 1993 heritage, it just will not go over 4k rpms its like there is a rev limiter. I did have the ignition and coil changed and it didnt make any difference. I do have a collapsed lifter and the pushrod was tightened to stop the tap, would that cause the motor not to go over the 4k rpms?
Old Aug 21, 2011 | 08:03 AM
JohnnyC's Avatar
JohnnyC
What ignition module did they put in? If it was stock ... my previous stock ignition module would only allow about 4,200 rpms. My new crane module allows you to set the rpms to what you want for your motor. I set mine at 6,200 and it cuts out at about 5,700.
Old Aug 21, 2011 | 08:08 AM
motohead20's Avatar
motohead20
3rd Gear
Its a single fire ignition and its set at 6500, if im cruising at say 40mph there is small poping from my exhaust. It might not be timed right but it still wouldnt stop the motor from running over 4k rpms.
Old Aug 21, 2011 | 08:30 AM
RA51's Avatar
RA51
I would say you need to do a compression check on the cylinder with the collapsed lifter. When you adjusted it just to make it quieter, you maybe holding the valve off the seat. You need to replace the lifters.
Old Aug 21, 2011 | 09:06 AM
ajayrk's Avatar
ajayrk
Damaged slide diaphragm. Diaphragm leaks and will not raise the slide to fully open. Look into carb throat and rev the engine. Slide should go all the way up.
Old Aug 21, 2011 | 04:14 PM
motohead20's Avatar
motohead20
3rd Gear
OK I tested the compression and the rear has 120 and the front where the collapsed lifter is has 100. So im guessing that the valve isnt closing all the way because of the pushrod being to tight?
natural gasser
EVO
Apr 20, 2017 06:01 AM
ZROADSTER
Apr 12, 2013 03:32 PM
Acemon
Shovelhead
Nov 16, 2012 05:53 PM
John1957
Shovelhead
Jul 22, 2012 03:08 PM
RidemyEVO
EVO
18
Jun 16, 2011 07:32 AM
