2010 power commander map.
Old Mar 10, 2011 | 01:17 AM
cursedspirit's Avatar
cursedspirit
Default 2010 power commander map.
Hey all,
messing with the bike and looking through some maps for the power commander V. Was wondering if anyone had a map for the power commander V that would be close to these specs?
2010 street bob
96 CI
V&H short shots
Arlen Ness super sucker
Figure i would through it out there to see if anyone had something close for that. Thanks all
Later
Jay
Old Mar 10, 2011 | 03:44 AM
Motorhead England's Avatar
Motorhead England
If anyone else hasn`t got an identical map to the one you require, I would install these and see which one you feel runs best..
M15-013-020 *Advanced Map*, Vance & Hines Big Shots Staggered exhaust, Screamin Eagle Air filter, Rev Xtend Enabled, Fuel Table 1 is front cylinder
M15-013-003 Vance & Hines Big Radius exhaust (standard baffles), Screamin Eagle air filter, Stock ECM, Table 1 is front cylinder
Regards..
Old Mar 10, 2011 | 05:16 PM
cursedspirit
Thanks I will try those two out and see how it rides.
Old Mar 12, 2011 | 08:40 PM
cursedspirit
Motorhead Thanks for the tip on M15-013-020 loaded that map last night and ran her today for a few hours. Got her running real good and smooth. Thanks again
Old May 3, 2016 | 05:35 PM
OzWobbles's Avatar
OzWobbles
6th Gear
Originally Posted by cursedspirit
Hey all,
2010 street bob
96 CI
V&H short shots
Later
Jay
I called Dynajet , v&hines and none helped me. I have a 2007 street bob with PC 5 and v&h sideshots it runs great but has a lot of decel pop anyone got numbers that will help ?
Old May 4, 2016 | 03:23 PM
Motorhead England
In the 0% throttle column enter the value 10 in the rev range 1750rpm thru 6500rpm.
Go on a test run, if it hasn't reduced the popping to your satisfaction increase the value in the 0% throttle column in increments of 5 until you are satisfied.
Regards....
Old May 6, 2016 | 04:59 PM
OzWobbles's Avatar
OzWobbles
6th Gear
Yo Motorhead you were spot on, I was not sure how to adjust never having done it before, I got your reply and watched a video on PC5 decel pop and ended up getting up to -80% 2000 through 6500 and that did it!
Now that I am confident in making adjustments I ended up using a Brockacre map and man it's strong without any decel pop.
Awesome man thanks.
OzWobbles
Old May 6, 2016 | 05:00 PM
OzWobbles's Avatar
OzWobbles
6th Gear
Regards....
Awesome man thanks.
OzWobbles
Old May 7, 2016 | 02:43 PM
Motorhead England
Awesome man thanks.
OzWobbles
You're welcome.
Glad to be of help.
Regards.
jdunn01
Mar 3, 2011 09:50 AM
Ford Lowrider
Mar 18, 2010 08:40 AM
Ford Lowrider
Mar 17, 2010 07:45 PM
Ring
Sep 30, 2009 08:04 AM
SFarace20
Jan 10, 2008 12:56 PM
