brake light problems
Old Mar 19, 2011 | 06:05 PM
Curious George's Avatar
Curious George
6th Gear
Default brake light problems
Hey guys I've got an 04 fxd and I was riding the other night and I realized that my brake light stays on when let off the brake. I haven't changed anything electrical wise. Any ideas on what might of happened? I checked all the fuses and all the connections look clean. Any ideas on what I should do would be very helpful. thanks guys
Old Mar 19, 2011 | 06:30 PM
bobnehoc's Avatar
bobnehoc
I would check the brake light switch. Could be either the front or rear switch has gone bad which is causing your brake lights to stay on. You could also check the brake peddle and brake lever to ensure they are properly positioned on the brake light switch.
Old Mar 19, 2011 | 06:45 PM
dyna rider's Avatar
dyna rider
Default Brake Light Switch
Have you changed grips or handlebars lately or over the winter ?
Old Mar 19, 2011 | 08:38 PM
Shovelhed's Avatar
Shovelhed
Definately the switch. Probably front. It seems to be a problem with em. It's a pain to change also, requires cutting wires and splicing...
Old Mar 20, 2011 | 01:06 AM
Curious George
6th Gear
great thanks guys
drsnipes
Dec 3, 2023 01:18 PM
redman53
Electrical/Lighting/Alarm
Apr 10, 2015 06:17 PM
Half-Fast Deuce
Sep 23, 2012 07:56 AM
norris
Aug 19, 2010 10:17 PM
Jonny Cannon
Jul 11, 2007 09:19 AM
