Stage one upgrade question
Old Mar 27, 2011 | 12:55 PM
jdaws's Avatar
jdaws
The Dephi ECM will compensate for the mods by mantaining the stock AFR which is on the lean side for emissions.
A tuner or fuel programer will modify the AFR to give you more power and a cooler running engine.
Old Mar 27, 2011 | 03:54 PM
Smokey Burnouts's Avatar
Smokey Burnouts
nice write up!!
Old Mar 29, 2011 | 05:06 AM
artpe54's Avatar
artpe54
May edition of American Iron has an article where they install D&D Boss Cats on an 2009 Road Glide along with a Zippers Maxflow air cleaner. No download or tuner.
Old Mar 29, 2011 | 10:16 AM
EasyMoney1027's Avatar
EasyMoney1027
Thanks so much for the info!!!
Old Mar 29, 2011 | 02:34 PM
The Gecko's Avatar
The Gecko
This is exactly why I wouldn't buy an older used carbureted Harley. I come from a back ground of riding dirtbikes and driving/racing fuel injected cars. Until you start really pushing serious power in a car to the point the stock fuel system can't flow enough fuel and you install larger injector or you add a power adder (or an extra power added in the case on my last ride) the stock computers in late model cars really are amazing in their ability to keep a safe air fuel ratio with mild mods (air intakes, exhaust and in the case of most cars even mild cams). I don't see why our new bikes should be different. When it comes time for a stage one for me I will be putting on a new air intake and pipes..... ride it for a bit and then pull the plugs before I blindly spend money on something that isn't needed. Spark plugs will tell you alot. But to play devils advocate, NOTHING beats a custom dyno tune on any motor. Even box stock the factories (car at least) always leave alot of power on the table.My 2 cents for what it's worth...
Old Mar 29, 2011 | 09:07 PM
jdaws's Avatar
jdaws
The Delphi system will try to maintain a stoichiometric air fuel ratio (AFR) of 14.7 to 1.
This is what it is programed to do to meet federal emissions.
A Harley engine runs the best at a AFR of around 13.5 to 1.
Look at an AFR scale on a dyno chart.
Adding a free flow intake and exhaust further leans out the AFR but the ECM will still try to maintain 14.7 to 1.
Adding a tuner or fuel programmer will give you the ability to change the AFR and fine tune it to where your engine will run at its peak.
Adding more fuel also has a cooling affect.
Stage 1 = Intake/exhaust/fuel programmer or tuner.
Old Apr 1, 2011 | 08:09 AM
RAWHIDE07's Avatar
RAWHIDE07
Looking at the maps found in www.tuneyourharley.com ,(hd fuel maps),it's apparent the HD stage 1 download does add more fuel ABOVE 3700 rpm or wide open throttle,the timing is also affected.Most actual riding is done below this point which is why the bike must stay EPA compliant at these rpm's.This is why the xieds work well because they will cause the ecm to add more fuel at 40% or less throttle.Whether or not the ability to add more fuel at wot and the timing changes along with the redline increase to 6200 vs 5500 rpm is worth the $150 is a personal decision.I believe that HD designed the stage 1 download to insure that the engine would not suffer a lean condition when being ridden in an aggressive manner,they are taking a conservative position which may not be needed.The nightrider xieds will work well with a stock or stage 1 download along with intake&exhaust changes.
Old Apr 1, 2011 | 08:11 PM
jdaws's Avatar
jdaws
This is the fuel managment system I use from Dobeck perfromance.
EJK Controller Key Feature Explanations
  • NO COMPUTER NEEDED
    The EJK controller is one of the only controllers on the market which allows a large range of adjustability without the use of a computer. We like to use the term 'on-the-fly' tuning. You can literally drive the vehicle, make setting adjustments, and instantaneously feel the results. Obviously for safety purposes we recommend you pull over to the side before making adjustments. Some after-market EFI controllers like to claim 'on-the-fly' tuning which to them means toggling only between a couple preset maps. The EJK controller actually has 11,390,625 available maps in the unit which are accessible without using a computer program to reprogram the unit. There does exist a computer program called POWERLAB and the EJK controllers can be reprogrammed by a computer, but most users do not require this ability. Why deal with the complexity? It's an Electronic Jet Kit to make fuel injection tuning easy, simple, and fast so you can enjoy more time riding.
  • NO DYNO REQUIRED
    You do not have to be a professional mechanic or tuner and have access to a dynamometer in order to tune your vehicle with the EJK controller. Knowledge and good equipment obviously are a huge plus, but you can do just as good a job and sometimes better by tuning in real world riding situations. The EJK controller allows this by breaking down a drive cycle into very understandable zones to make adjustments. Most EJK controllers have the basic Idle/Cruise, Acceleration, and Full Throttle zones to adjust. Every rider can understand this terminology. The greatest advantage about tuning your vehicle yourself is your ride will be custom set up to your driving style.
  • Plug N' Play Installation - Minutes to Install, Base Settings are Preset
    All of the offered EJK controllers are plug n' play installations and can be done in a manner of minutes instead of hours. All you have to do is locate the OEM injector connections on your vehicle. Most of the time this will only require you to remove a few components to gain access to these injector connections. A number of new applications will also require you to find the O2 connections on your vehicle if present. Power for the unit is gained through the injector connections and a black ground wire just needs to be attached to the negative terminal on the battery if present or by a metal screw onto the vehicle frame. After physically installing the EJK controller in most cases you are all set to go on a test ride. The unit comes pre-programmed for a stage 1 setup for each application. After your initial test ride you then can make some fine tune adjustments which may be required based upon your modifications.
  • Uses Unique Load Based Technology
    The EJK controller uses Load Based Technology which sets it apart from most of the competition. Most EFI controllers use what is called 'Alpha-N' Tuning Technology. Alpha-N tuning is associated with just using Throttle Position (TPS) and RPM as the factors to make tuning adjustments. Load Based Technology differs by using Rate, TPS and RPM as the key factors for adjustment. Load Based tuning allows a user to tune their vehicle for every gear and for all riding conditions. Load can easily be explained by stating that riding up a hill puts more "load" on the vehicle than driving on a flat road, but yet the same TPS and RPM can be achieved in both circumstances.
  • Offers Full Range Tunability
    EJK stands for Electronic Jet Kit. Like carberator jet kits of the past the EJK offers a range of adjustability to tune your vehicle. Instead of physical jets and needles the EJK has this adjustability built into the unit and can quickly be adjusted while riding the vehicle. Essentially with all EFI vehicles software has replaced some hardware. The EJK controller can be installed and set to actually allow the user to still run a stock configuration, but allows the user to ADD or PULL fuel within easy to understand tuning zones.
  • Does Not Interfere with Stock ECU Operation
    This is a very common feature of all aftermarket EFI controllers, but needs to be stated to reassure all end users. The EJK controller does not trip any engine codes or affect the ECU operation in any way.
  • Simple Push Button Adjustment Interface
    The EJK controller offers 'on-the-fly' adjustment using three push buttons on the label interface. The three buttons are labeled MODE, PLUS, and MINUS. With power supplied to the box by either starting the vehicle or just turning the key on, the adjustment modes are accessed by pressing the MODE button. Light setting changes are then made for each respective mode by pressing the PLUS and MINUS buttons. No extra tools are required to make tuning adjustments.
Old Apr 1, 2011 | 09:40 PM
05dyna88's Avatar
05dyna88
Old Apr 2, 2011 | 05:11 AM
Foxster's Avatar
Foxster
That's not quite correct. The Harley EFI does maintain stoic AFR but only in closed loop. Once outside that, the AFR is set from 12.5 to 13.5 depending on load and RPM.
