Stripped threads
Stripped threads
The bolt to fasten my seat atop the rear fender of my 05 FXDI will no longer stay fastened. Even with liberal amounts of loctite. I've purchased new bolts from the dealer. Still no luck. I guess the threads have been stripped out in the well were the bolt is supposed to be seated. Any options, quick fixes, or warnings? Thanks in advance.
59768-97 FENDER-SEAT NUT KIT
I fed a cord from the topside of the fender down, slipped the cord through the fender nut and made a "stop-knot" , pulled the cord up into the fender and slipped the clip on to the nut.
You could also use a tie-wrap: slide the nut onto the tie-wrap..then feed the tie wrap up along the rear tire into the fender hole and slip the clip onto the nut...
