is there any need
Old Apr 16, 2011 | 02:25 AM
blink1968's Avatar
blink1968
Default is there any need
is there any need to run a set of nightrider xieds with a vance and hines fuelpak ?????? hurt it or help it???
Old Apr 16, 2011 | 06:12 AM
Krazy8s's Avatar
Krazy8s
As far as I understand running both would simply be having 2 things to do the same job. Remove one, it is unnecessary.
Old Apr 16, 2011 | 08:28 AM
Foxster's Avatar
Foxster
Umm, actually Nightrider (makers of Xieds) do suggest it as a good combination and I can kinda see it.
The fuelpak tends to cover the open loop area i.e. the high speed & acceleration bit. However, not so much the closed loop bit. This because the stock ECU is still reading the O2 sensors and will try to compensate for richness in the closed loop area introduced by the fuelpak back towards stock AFRs.
So fitting some Xieds too will richen up the closed loop bit and the fuelpak will handle the open loop.
Old Apr 16, 2011 | 08:53 AM
Slipstrm's Avatar
Slipstrm
I run both on both of my Harleys. I can tell a difference.
Old Apr 16, 2011 | 10:13 AM
Krazy8s's Avatar
Krazy8s
There you go, I learn a new thing every day
truckerdave
The Dyno Room
Jun 24, 2016 10:08 AM
rscott
Feb 6, 2016 07:56 PM
latrobedyna
Jun 27, 2013 11:23 PM
straniero
Mar 28, 2009 11:45 PM
joeld0803
Jul 6, 2007 11:26 PM
