Received C&C Solo Seat
Old 05-06-2011, 05:45 AM
ciacalsab's Avatar
ciacalsab
ciacalsab is offline
Default Received C&C Solo Seat
Need help from a lady rider. I received my solo seat the other day and I want to install it on my FXDL. I removed the two up seat, but there is no room under the fender for me to fasten the solo seat on. What is the trick to do this? I will post pics when I finally get it installed.
Old 05-06-2011, 06:33 AM
maddghost's Avatar
maddghost
maddghost is offline
There should be a black plastic cap under there right where the seat should anchor down with a HD logo on it which needs to be popped out. It isn't held in by much at all and I usually just try to get a finger nail in not to scratch the finish and it should come off really easily. Once that is out you will need to remove the metal piece tha the 2 up seat was screwed into and install that in the hole you made pulling out the other plug. put the plug in your further back hole, for aesthetics and install the metal piece into your forward hole. Or buy another ( 6$ i think) but it won't be pretty te leave that part there just bounceing around. How to get the metal piece into there between the tire and fender is to run a ty-wrap through the piece and poke the end of said ty-wrap up through the hole and pul it up until you get the piece into place. add the little plastic clip to hold that into place and your ready to screw your new seat down.
PS guys no cracks obout the forward and back holes where my terminology may be lacking ! And no pun intented withe the crack niether!
LOL have a good one and I hope this helps!
Old 05-06-2011, 07:55 AM
fenderzig's Avatar
fenderzig
fenderzig is offline
Not quite what you were looking for but how do you like the seat? Mine's coming next week and by the looks of yours I think I'm going to be real happy!
Old 05-06-2011, 10:13 AM
EricInNCa's Avatar
EricInNCa
EricInNCa is offline
Great looking seat! maddghost pretty much nailed it...
Old 05-06-2011, 10:14 AM
ciacalsab's Avatar
ciacalsab
Very impressed with the seat. They did a fantastic job. You will be pleased also. Post pic when you get it..
Old 05-06-2011, 10:17 AM
ciacalsab's Avatar
ciacalsab
Thumbs up
Thanks Maddghost. I will give it a try.
Old 05-06-2011, 10:27 AM
greenstreetbob's Avatar
greenstreetbob
greenstreetbob is offline
Good looking seat. Would like to see it installed.
Old 05-06-2011, 10:48 AM
Black Bart's Avatar
Black Bart
Black Bart is offline
You got it installed yet?
Old 05-06-2011, 02:56 PM
ciacalsab's Avatar
ciacalsab
I don't have it installed yet, just got home from work. Going to do our best this weekend to get it done. I will post pics for sure when it's on.
Old 05-07-2011, 08:46 AM
ciacalsab's Avatar
ciacalsab
Hey Maddghost, I thank you and hubby thanks you. That was so simple, seat was on in two minutes. It saved alot of work. I will post new pics in a little while.
section8joe
10-05-2009 01:35 PM
Handycam
06-09-2009 06:50 PM
mpaquette
04-27-2009 12:55 PM
p8nter
02-19-2009 02:36 PM
2007fxdc
11-01-2007 01:40 PM
Quick Reply: Received C&C Solo Seat
