Shifter Shaft Seal
Old May 12, 2011 | 09:05 AM
Ajackson9687's Avatar
Ajackson9687
Default Shifter Shaft Seal
Replacing a shift shaft seal on a 1993 Low Rider, anyone know if all I need is that seal and the primary gasket kit? Anything else I will need that anyone can think of? And anyone know the size of the head on the comp nut and clutch hub nut off the top of their head?
Old May 12, 2011 | 06:46 PM
Robtarra39's Avatar
Robtarra39
I just had the main shaft seal replaced, aslo starter pinion seal, it's a case of while in there may as well replace all these seals, as you don't want to have to go back in. 1 1/4 and 1 3/16 if i remember coreclty
Old May 13, 2011 | 09:16 AM
Ajackson9687
Thanks =]
fournierrandy
Aug 19, 2018 06:35 AM
Neil
May 31, 2017 11:00 AM
Kaycee
Apr 30, 2013 06:49 PM
BigDaddyMongo
Jun 5, 2011 07:39 PM
bugmann78
Ironhead
Feb 8, 2008 01:15 AM
