electrical connection
Old May 17, 2011 | 07:50 PM
ultradyna's Avatar
ultradyna
Default electrical connection
can someone tell me where I can connect a hot wire for an accessory that is only hot with key on
Old May 17, 2011 | 07:58 PM
RANGER73's Avatar
RANGER73
Whats the load of the acc.? If it's to large, you'll need a fused relay controled from the Acc. or light terminal on the ignition.
Old May 17, 2011 | 08:09 PM
ultradyna's Avatar
ultradyna
it is a turn on lead draws less than 1/2 an ampere it tells the amp to turn on for the hogtunes handlebar system
Old May 18, 2011 | 01:34 AM
HemiOrange's Avatar
HemiOrange
If your ign switch is mounted on the front right frame at the steering head, there is a plastic cover over the wiring on the under side, right under the switch, that you can pull off. Fish out the wire bundles and look for the bundle going to the switch. Inside this bundle will be 3 wires, a red one, a red/grey and a red/black. The red is hot all the time, the red/grey is hot in either acc or ign and the red/black only hot with the key turned to ign.
These 3 wires are inside a plastic sheath that you will have to slice open.
You might be able to locate the wires somewhere else, but this is where the acc wires originate. Check your wiring diagram to find other locations.
Old May 18, 2011 | 04:31 AM
Squirrel67's Avatar
Squirrel67
There is 2 under the seat ready to go.
Old May 18, 2011 | 01:59 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
+1; it's called the customer accessory connector..
check out this link from my ***Dyna Models Wiring Diagram Links Index*** for a wiring diagram
2008 all dyna dom. & int. models (except FXDWG, FXDC, FXDF) main harness page 1 of 3
You'll find the 4 pin black Deutsch connector in the center right hand side part of the diagram...
Old May 18, 2011 | 03:54 PM
08fxdf43202's Avatar
08fxdf43202
That's the connector I used for a power outlet that I mounted to the bottom of the battery box.
The power lead has a 15 amp fuse.
The connector is under the seat.
I had a male & female 2 pin connector laying' around so I took the 4 pin Customer Accessory Connector apart, shrunk shrink wrap over each terminal on wires 2 & 3, folded them back and insulated/secured them with a piece of shrink wrap over the other two wires... I was then able to use wires 1 & 4.
I have no idea what the single hot wire labeled 'P&A Battery' is for, I didn't use it because it's hot all the time.
If you decide to use the 4 pin connector you can get the other end for it from:
http://www.deutschconnector.com/prod...es_connectors/
http://www.jegs.com/i/JEGS-Performan...arentProductId=
XL-erate
Dec 13, 2024 04:21 PM
MJR35
Aug 4, 2018 04:30 PM
prodgers
Oct 3, 2011 03:44 PM
jimsuver
Aug 21, 2010 04:33 AM
Big Twi$t
Oct 20, 2008 04:25 AM
