short shot problems
Old Jun 6, 2011 | 09:56 PM
teamdooracer's Avatar
teamdooracer
Default short shot problems
I just put vance and hines short shots on my 11 wide glide. I can not get the black shields to have they same amount of chrome pipe showing at the end. (If that makes sense). The top pipe has about a 1/4 inch sticking past the shield and the bottom pipe has like a 1/2 inch. Anybody else have this problem.
Old Jun 7, 2011 | 04:25 AM
tallboy21's Avatar
tallboy21
1st Gear
Just moving the hose clamps down and retightening them where you want them doesn't help? Are the hose clamps hitting something? Should be able to move them wherever you want.
Old Jun 7, 2011 | 06:04 AM
fenderzig's Avatar
fenderzig
This is what I was thinking. I installed a set of short shots about two months ago and I didn't have this problem. I did have to manipulate the clamps a bit though.
Old Jun 7, 2011 | 06:22 AM
04FXDL's Avatar
04FXDL
Are you talking about the short shots STAGGERED like in fenderzig's sig. or the regular short shots, which have the flush ends? Flush ends won't allow for adjustment as far as I know. The staggered ones should have plenty of room to adjust, make sure your not hung up on anything and the hose clamps should have some movement.
Old Jun 7, 2011 | 05:04 PM
teamdooracer
I have the staggered. I had all the clamps loose and it seemed like they only wanted to sit good in one spot. I'll have to take a closer look. Maybe one of the clamps was just binding.
kite
May 16, 2011 06:25 PM
Rickr01
Apr 25, 2011 10:14 PM
lukemc7
Dyna Models
Feb 28, 2011 02:43 PM
Chief79
Aug 30, 2010 08:47 AM
Jeepin79
Jun 23, 2010 03:38 PM
