Axle Info:
2000-03 Dyna have ž” front axle, 2004-07 Dyna have 1” front axle (except 2004-05 FXDWG), 2000-05 Dyna have 3/4” rear axle, 2006-07 Dyna have 1” rear axle. 2000-05 FXDWG have ž” front and rear axles, 2006-07 FXDWG have 1” front and rear axles. All Dyna have 25mm axles from 2008+.
Info from J&P Cycles Catalog.
Hello,regarding switching of bearings.The 25mm bearing is narrower also,therefore if the hub is for a 25mm the 1in bearing will not seat in place all the way in,sticks out about 1/8th in.Just went thru all this putting a custom wheel from a 2010 onto my 03.Had to get a 25mm axle.and use 25mm bearings.the fork lowers are the same.
