Rusty Bolt
Old Jun 23, 2011 | 05:48 PM
OldMike's Avatar
OldMike
I doubt if it's stainless steel, I've not had stainless rust on me. It's probably cad plated, just replace it.
Old Jun 23, 2011 | 06:19 PM
lo-rider's Avatar
lo-rider
Originally Posted by JT-FXDL
...So if it's magnetic, it CAN rust?
You got it.
Old Jun 23, 2011 | 06:33 PM
JT-FXDL's Avatar
JT-FXDL
Here are some pics. I did clean it yesterday with WD-40 and a wire brush. It does look better today but it's still rusty on the sides and bottom and if it rusted once it most likely will again.
It's the bolt right below the number stamp, right behind the shift linkage. Does anybody know what this bolt is for and if it is short enough to get out being behind the primary?
Old Jun 23, 2011 | 07:16 PM
JT-FXDL's Avatar
JT-FXDL
Originally Posted by lo-rider
You got it.
Okay, it does seem to be attracted to a magnet.
Old Jun 23, 2011 | 09:53 PM
missedem's Avatar
missedem
go to the auto parts store and buy some royal jelly and clean the bolt up with a tooth brush. I have used this stuff all over my bike. just be sure to wipe it clean with a rag when done and wash it off with soap and water since it is corrosive. It works great on rust removal and does not seem to weaken the metal any. Ive used this stuff on sissy bar bolts etc . if a bolt gets wet enough or is in humidity long enough it will rust.
Old Jun 24, 2011 | 07:19 AM
Peter Black's Avatar
Peter Black
Wow thats what your so worried about stop being a girl! spend less time cleaning and more time riding.
Old Jun 24, 2011 | 11:29 AM
JT-FXDL's Avatar
JT-FXDL
LOL... I know, right? But I guess I just picture a stream or rust over time flowing down my black engine block, and then a mechanic (or me) not being able to get the bolt out because the head has eroded away. I'm also curious as to why this is the only bolt that is rusting, and why it's even there... I can't figure out what it is bolting together.
Old Jun 24, 2011 | 12:07 PM
canadiancruiser's Avatar
canadiancruiser
remove rust with rust remover wash it off letit dry the throw some clear coat on it
Old Jun 24, 2011 | 12:22 PM
j1mmy's Avatar
j1mmy
that bolt is probally a few inches long,holding the shift drum inside of the trans..if you pull it out,you will be pulling the trans to reassemble it..just wire brush it if it bothers you that much..brush some black paint or grease on it to protect it..the cad plating probally got chipped when it was built..it wont rust out or cause any problem..a chrome cap will cover it too
Old Jun 24, 2011 | 12:27 PM
JT-FXDL's Avatar
JT-FXDL
I was afraid of that...
That sounds like a good idea to me, thanks.
