I am still trying to install my mini tach on my 03 low rider I redid the dash and installed a mini tach and hooked it up just how the old one was hooked up and I am not getting a signal anyone got any ideas Thanks
Which Mini-Tach do you have? Is it an H-D 2-5/8" Mini-Tach? If so, it doesn't connect to the coil signal wire, it connects to the VSS /Serial Data Link wire. The same wire that goes to the speedometer. If your previous tach was a conventional tach, that could be the problem.
Reason: Clarification/additional info
The black went to ground I think the orange was power and the pink for the signal, I have power to the tach it lights up but I have no signal
Are the wires hooked up correctly inside the tach housing? if the orange and black wires are reversed, the tach will still light up, but of course it won't work. Don't ask me how I know that.
That's the problem. The Mini-Tach DOES NOT connect to the stock tach signal (Pink wire) coming from the ignition module. You need to connect the Pink Mini-Tach signal wire to the White/Green wire that goes into Pin 2 of the speedometer connector.
I looked at the wiring diagram and I see what wire you are talking about, what is the best way to slpice into that wire should I just cut it and splice my tach signal wire into than solder it or is there a better way Thanks for your help
From what I'm reading in the Mini-Tach instructions and service manual right now, the Pink wire from the ignition module should be working for you. Are you sure the wires inside the Mini-Tach housing are connected correctly?
