Thundermax Issue---Need Help
Old Jul 6, 2011 | 10:38 PM
HD Bobber's Avatar
HD Bobber
Question Thundermax Issue---Need Help
So lately zippers made a software upgrade with new maps added.
With my old map I never had an issue (I also made sure I have the correct speedo claibration numbers for my bike).
Once in a great while when I ride the speedometer wont work, Battery light will go on, engine light, and the security key light will go on. Once I restart the bike the problem is fixed.
Barley happens, but still it bugs me.
ANYONE HAD THIS PROBLEM?
Old Jul 6, 2011 | 11:04 PM
Bspike1's Avatar
Bspike1
I haven't had an issue after the upgrade. Sounds like an intermittent power issue (losing ground or bad switch).
Old Jul 6, 2011 | 11:13 PM
AFHuey's Avatar
AFHuey
Not having issues on my T-max. It sounds like a ground issue to me, but what do I know?
I'd check your dielectric grease in your connector and see if you have a bit of moisture or corrosion messing with you.
If not, give your gremlin bell a wiggle.
Old Jul 6, 2011 | 11:15 PM
Bspike1's Avatar
Bspike1
+1 on that
Old Jul 8, 2011 | 05:09 PM
mike634's Avatar
mike634
I was having a problem with mine. I ran the initialization procedure and it has been fine since.
Old Jul 8, 2011 | 09:01 PM
nevil's Avatar
nevil
I had that problem happen twice. Called Zippers and they said the ECM loses communication. They recommended using dielectric grease on the main plug and if possible put on a cable tie to keep the 2 parts tight together. No problems since.
While I was at it I also cleaned up the fuses and relays and gave them a coat of grease.
Don't forget to pull the ECM fuse before you disconnect the plug.
Old Jul 9, 2011 | 02:30 AM
Foxster's Avatar
Foxster
Firstly, if it aint broke, don't fix it. If it was working fine before then why do an 'upgrade'?
Second, sounds like a loose battery connection. Could be you disturbed an ailing connection while messing with the TM this time. Try taking the battery leads off, clean things up and reassemble tightly.
schwingding
Sep 15, 2011 06:26 AM
GENRLEE01
Dec 25, 2010 08:59 AM
WildBill2566
Jul 31, 2010 07:29 AM
bdavis385
Jun 1, 2008 10:24 PM
matkiwi
Aug 6, 2007 12:49 PM
