new 07 CVO Dyna bars finally in
Old Nov 9, 2006 | 06:25 PM
dxrich's Avatar
dxrich
Default RE: new 07 CVO Dyna bars finally in
my similar bombay bars on the street bob. I did this before i saw the cvo. Nice to see HD likes my idea !
Old Nov 9, 2006 | 07:41 PM
Beagle1's Avatar
Beagle1
ORIGINAL: kpreese
Beagle1,
You have a WG correct? You definitely have a different speedo than I do and I have heard of others where the speedo pin works. That's why I suggested that he try it first. That probably explains it though. I hooked it up TWICE on mine just to make sure I got a good connection. I know of someone that has a SG Custom and his speedo pin 3 didn't work either.
Kevin
Kevin, You didn't have the pink wire tucked up in the harness either? I had to cut it completely off to find it. Then I taped up back up with friction tape like used on Automotive wiring harnesses.
One thing I have learned from 21 years of wrenching on internal combustion powered stuff...many times there are changes in mid-year or something. I had many a FoMoCo harness that didn't match the wiring diagram when trying to find a short, etc. Really sucks when the color wire you are looking for is now a different color due to supplier changes...rocket scientists I tell ya'.
-Ron
Old Nov 9, 2006 | 08:11 PM
jmbear328's Avatar
jmbear328
kpreese,
What Springer front end is that you have on your bike? Man it looks great on there.
John
Old Nov 9, 2006 | 11:20 PM
jmbear328's Avatar
jmbear328
johnpiech,
From the looks of my setup you can just add the bombay bars and the tach if you like. I'll check it out when I get home this evening and make 100% sure but it shouldnt be a problem and will then look similar to the one on dxrich pics.
John
Old Nov 9, 2006 | 11:39 PM
kpreese's Avatar
kpreese
ORIGINAL: Beagle1
Nope, totally different speedometer and there is nothing but a single detachable connector on the back and no extra wires in the dash anywhere either. I split open the sheathing when I did another wiring related project and there wasn't a pink wire hidden up there either. It was a bummer at first. Even the service guys said I'd have to get some kind of signal pickup thing to hook to one of the ignition coils. The signal wire on my mini tach was yellow and I think most are pink.
ORIGINAL: jmbear328
It's from a 1996 Bad Boy. Here are two better shots:
Kevin
Old Nov 9, 2006 | 11:52 PM
jackyl's Avatar
jackyl
sharp and clean.good choice
Old Nov 10, 2006 | 01:29 AM
lowriderfxr's Avatar
lowriderfxr
[IMG][/image]
Here's what the set up looks like on the sefxdse
Old Nov 10, 2006 | 01:40 AM
PsTaN's Avatar
PsTaN
Bars look clean John ..... good work.
PsTaN
Old Nov 10, 2006 | 03:39 AM
Vegas P11's Avatar
Vegas P11
3rd Gear
Those bars look wicked on there. Great looking bike. I'd love to pu em on my 06 Low Rider but what do I do with the idiot light mounts that are part of the riser top mount? Any ideas?
Old Nov 10, 2006 | 08:43 PM
jmbear328's Avatar
jmbear328
Beagle1,
Hey thanks for the help. As it turned out I had to get the Tach signal from the #3 pin in the ECM. I got it working and just cant wait until the main speedo harness arrives so I can get it all togeather and get some riding in now.
John
