2000 FXDX sissy bar????
Old Jul 21, 2011 | 01:41 PM
Good_Apollo's Avatar
Good_Apollo
Default 2000 FXDX sissy bar????
I am having a heck of a time finding a black sissy bar (or any sissy bar for that matter) for my 2000 FXDX. The 2000 and 2001 FXDX had a different rear fender and width than the rest of the models so the other bars won't fit. I am putting a quick detach sissy bar on for the girl. I have the correct docking hardware kit which is part #53839-00
The correct side plates are easy to come by and are part #53834-00A
These two things are easy to find, but now I can't find a dang sissy bar to get this stuff to work! If I can't find one I may have to have the indie/builder I know weld one up for me which will probably cost more than just buying one if I can find it.
Old Jul 21, 2011 | 02:58 PM
JRK5892's Avatar
JRK5892
let me know bud i am sure we could weld up and coat an upright for you. may also look at some of the sloppy tails and even sportys to see if those will fit your side plates
Old Jul 21, 2011 | 11:52 PM
Deadwood's Avatar
Deadwood
No doubt side plates are different but I use a sissy bar from a 2005 Softail.I use the whole sissy bar though and only because it was given to me.
Let me know if you want some measurements taken.
Old Jul 22, 2011 | 05:23 AM
JohnC FXDX's Avatar
JohnC FXDX
I have a Harley brand bar on mine. If you look at the parts section on the HD website, it is still there. Mine's a 2001. I do notice that when I search for aftermarket items for the FXDX, not too much stuff comes up. If I change the search to FXD, a lot more things pop up. I did not know that the rear fenders were different than the regualer Dyna though.
Attached Thumbnails 2000 FXDX sissy bar????-dsc01001.jpg   2000 FXDX sissy bar????-dsc00990.jpg
Old Jul 22, 2011 | 01:07 PM
Good_Apollo
Only on the 2000 and 2001, the FXDX had 150mm rear tire that year and a fender to compensate, the rest of the Dynas still had a more narrow tire. They all had the wider tire in later years.
Old Jul 22, 2011 | 01:17 PM
Phrogman's Avatar
Phrogman
Your best bet is to either buy the chrome one from Harley and get it coated, or have someone custom bend some square stock for you and coat that. There shouldn't be any welding involved if all you're looking for is a sissy-bar similar to the stock Harley type. Unless you want them to weld in the plate for screwing on a pad, but for that you can get pads that use the spanner bar on top and bottom.
rydahog
Apr 24, 2026 02:55 AM
7.3 Dave
Dec 21, 2015 12:30 PM
Highgrade
Jul 4, 2015 08:46 AM
Trouble57
Aug 25, 2012 11:47 AM
sneeky007
Aug 24, 2007 11:45 PM
